Page 4 of 4 1 2 3 4
Re: 563 Dyno results [Re: JERICOGTX] #3090777
10/31/22 04:50 PM
10/31/22 04:50 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by JERICOGTX
Originally Posted by n20mstr
nobody got the Spacer joke??? shruggy
Nice car for sure, great detail
Thanks Tony. I got the joke. No way I'm touching that stuff. I have a hard enough time not wrecking anything. Don't need to add melted pistons to the mix.
??? COME ON NOW.....ITS VERY VERY SAFE.....I JUST removed my 530" and its got 75 passes, all from a 136 jet up to a 150 jet. Every hole still pumps more cranking comp then when it was fresh. Your engine would barely notice a 73 or 82 jet, and im sure it would be solid into the 8's
....BAD A$$ STREET CAR.....
Re: 563 Dyno results [Re: JERICOGTX] #3090805
10/31/22 07:12 PM
10/31/22 07:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The good part is Tony's spacers are the variable HP type drive
Re: 563 Dyno results [Re: JERICOGTX] #3090810
10/31/22 07:41 PM
10/31/22 07:41 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Come on Jeff! Make that LIBERTY work! Here's a Liberty rowing 15 YEARS ago! biggrin
The GTX looks and sounds nice man! Nice job....
"Any fool can know. The point is to understand"
- A. Einstein
Re: 563 Dyno results [Re: n20mstr] #3090815
10/31/22 08:27 PM
10/31/22 08:27 PM
MN
JERICOGTX Offline OP
MN
Quote
I don’t think most people understand just how shoestring budget of a racer I am? I’m lucky if I can race a couple times a year. Just a bracket racer that wants to have fun.
69 GTX 68 Road Runner
Re: 563 Dyno results [Re: JERICOGTX] #3090827
10/31/22 09:17 PM
10/31/22 09:17 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Quote
If you built a 12 sec car you could go 4 or 5 times a year drive boogie
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 563 Dyno results [Re: B3422W5] #3090839
10/31/22 10:15 PM
10/31/22 10:15 PM
N
n20mstr Offline
n20mstr  Offline
N
Jeff , is that upper hose 12an?? and what brand hose and fitting is it?? THanks
Re: 563 Dyno results [Re: JERICOGTX] #3090861
10/31/22 11:49 PM
10/31/22 11:49 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Most are in the same boat. Good luck and have fun.
- A. Einstein
Re: 563 Dyno results [Re: n20mstr] #3090875
11/01/22 06:22 AM
11/01/22 06:22 AM
MN
MN
Yes, the radiator hoses are -12AN. I cut off the stock inlet/outlet on the radiator, and welded on bungs. The radiator looks somewhat stock, but is aluminum.
Page 4 of 4 1 2 3 4
