2000 Dodge Ram Ram Brake Lines #3090448
10/30/22 12:02 PM
10/30/22 12:02 PM
KY
65pacecar Offline OP
KY
Need to replace steel brake lines on a 2000 Ram. Any experien,e with Lines to Go? Also, any other suggestions? Debating on going with SS.
Re: 2000 Dodge Ram Ram Brake Lines [Re: 65pacecar] #3090500
10/30/22 03:50 PM
10/30/22 03:50 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Dorman lists them for a 2000 RAM. You should be able to get them pretty much any auto parts place. When I replaced mine they were still available from Mopar. I don`t think they are anymore.
Re: 2000 Dodge Ram Ram Brake Lines [Re: mopars4ever] #3090523
10/30/22 05:35 PM
10/30/22 05:35 PM
KY
KY
Thanks.
Re: 2000 Dodge Ram Ram Brake Lines [Re: 65pacecar] #3090545
10/30/22 08:06 PM
10/30/22 08:06 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I watcha shop owner on YouTube and he hates Dorman products. But for the 2000-2010 Chevy trucks he said the SS brake lines from Dorman are fantastic.
Keep old mopars alive.
Re: 2000 Dodge Ram Ram Brake Lines [Re: 2boltmain] #3090612
10/31/22 08:07 AM
10/31/22 08:07 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
when i replaced the rear lines in my ram i bought the cheapest prebent i could find on ebay. i also bought the mid line also.
when i did the work i should have just bought the rear axle lines. the mid line can easily be made yourself. unless you want exact replacements the mid line is just a straight line back to the axle.
in all honestly if i was using a hoist instead of laying on my back in the driveway, it only took an hour or so. i have a 2" lift on my truck, i didn't have to use a jack to do the work.. i should have bought some new ends and made my own and save a few $$$.. i also replaced the axle flex line and new bleades in the WC if it matters.
disclaimer...i have a rusty POS beater truck i really don't care what it looks like.
also i have a induction heater so i didn't have to use a torch to heat things up. this tool made the work pretty easy.
perception is 90% of reality
Re: 2000 Dodge Ram Ram Brake Lines [Re: Mr T2U] #3090631
10/31/22 09:58 AM
10/31/22 09:58 AM
KY
KY
Thanks for the replies.
Re: 2000 Dodge Ram Ram Brake Lines [Re: Mr T2U] #3090710
10/31/22 02:03 PM
10/31/22 02:03 PM
moparx Offline
moparx  Offline
MrT, what induction heater do you have ? [TIA ! up bow]
beer
Re: 2000 Dodge Ram Ram Brake Lines [Re: 65pacecar] #3090786
10/31/22 05:49 PM
10/31/22 05:49 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
https://www.brakeconnect.com/cunifer-brake-line
sample quote
It is a material known as Cunifer – an alloy of copper and nickel with a bit of iron and manganese thrown in for good measure.
In the world of metallurgy, this material goes by the names of Copper-Nickel CA 706, Cupro Nickel 10%, and C70600 and, as mentioned Cunifer alloy. In actuality, the alloy consists of 88.7% cop-per (Cu), 10% nickel (NI) and 1.3% iron (Fe ),although I have seen specifications listing 0.8/0 manganese (Mn).
For those of you who are not chemists or metallurgists, the previous paragraph was probably wasted, but it is important in that this special alloy makes a wonderful substitute for the traditional steel brake tubes used on our cars.
snip
This alloy provided superior corrosion resistance to steel, was malleable, easy to work with and easy to flare, was strong and had most of the benefits of copper tubing without the liability of work hardening. The inclusion of the nickel, steel and manganese made it stronger than copper alone, but still short of the strength of steel.
snip
You can buy just what you need, flare it yourself and install it as easily as you would regular copper line.
When you buy it though make sure that you order the correct fittings for brakes. They ARE NOT the same as the plumbing fittings that you buy at the local home building center. Brake fittings require special flares at the ends. Compression fittings are NOT acceptable, nor are single flares. A double flare is much stronger than a single flare, and is not a lot more difficult to make.
end quote
Re: 2000 Dodge Ram Ram Brake Lines [Re: 360view] #3090791
10/31/22 05:57 PM
10/31/22 05:57 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Around here they call that ni cop been using it for9-10 years for brake&fuel line,it don't rust or corrode never had to replace any of it yet.Great stuff.
Re: 2000 Dodge Ram Ram Brake Lines [Re: moparx] #3090801
10/31/22 07:06 PM
10/31/22 07:06 PM
Mr T2U Offline
Mr T2U  Offline
beer
i don't know the exact brand name. about 8 years ago i googled induction heater kits for sale and a company in china popped up. the main tool looks exactly like this ebay kit.. my storage box is different and i got 3 more ends.
https://www.ebay.com/itm/285001041551?
i have used it about 30 times in the last 8 years since i bought it. without any problems.
Re: 2000 Dodge Ram Ram Brake Lines [Re: Mr T2U] #3090876
11/01/22 06:43 AM
11/01/22 06:43 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Re: 2000 Dodge Ram Ram Brake Lines [Re: 65pacecar] #3090882
11/01/22 07:32 AM
11/01/22 07:32 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I have had good luck with Inline Tube. Recently bought their SS set for an XJ with ABS and it was spot on.
Inline Tube
Found cheaper on their ebay store, saved shipping.
Re: 2000 Dodge Ram Ram Brake Lines [Re: njmopar] #3090909
11/01/22 09:55 AM
11/01/22 09:55 AM
KY
KY
Thanks.
