stainless trim polishing #3089686
10/27/22 04:18 PM
10/27/22 04:18 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Does anyone have a source to polish windshield surround trim in the Atlanta area
Re: stainless trim polishing [Re: TrueTripleX] #3089941
10/28/22 03:09 PM
10/28/22 03:09 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Good work is gettikng to be hard to come by, and when it is cost are way up. Quality down, long wait times and high cost
A friend has a plating shop has soured my supplies but are higher priced but work bettter.
Ever reconsidered sending stuff out and doing it in house?
If you can do body work you can do stainless.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: stainless trim polishing [Re: 340SIX] #3089943
10/28/22 03:22 PM
10/28/22 03:22 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
It's not hard to do just labor intensive depending on the condition of the parts.
Re: stainless trim polishing [Re: Neil] #3089944
10/28/22 03:32 PM
10/28/22 03:32 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Lots of good videos on the internet on how to do it yourself. I did my own after watching a few.
If they are not twisted badly, bent or pitted, doing it yourself just takes some time, patience and practice.
Small body hammers, a good set of fine files and a comfortable work station, I have a adjustable bench top and a comfy chair, helps a lot to.
As for polishing, get a true polishing motor, not your bench top grinder, and put it on a stand where you have room to easily move the parts around!
My Monster are real!
Living within your means makes life pretty easy.
Re: stainless trim polishing [Re: 67vertman] #3089977
10/28/22 05:08 PM
10/28/22 05:08 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I did my own on this car . 1st ones Ive ever done . Youtube is your friend trust me
Its not perfect by any means . But I was really happy with it .
The front wheel lip mldgs were hurt pretty good so I let the professionals do them ( local shop here in Tucson ) and they came out fantastic .
They do NOT do any re-annodizing though
I sold the car this week and the new owner was happy with them as well
Re: stainless trim polishing [Re: TrueTripleX] #3093433
11/11/22 12:59 PM
11/11/22 12:59 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I can't help, but agree with all comments I saw below. I scored a near new 2HP Baldour buffer for $100, spent another $70 on a stand, another $130 on supplys/apron/gloves/shield. All because I want to do my windshield surround.
If you have to buy equipment, it ain't cheap to do it yourself. And its mostly labor, so it ain't cheap to pay someone.
Re: stainless trim polishing [Re: Vert] #3093482
11/11/22 02:50 PM
11/11/22 02:50 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I polished all the trim myself with my bench grinder and Harbor Freight pads and compounds. Having a dedicated polisher on a stand that is not attached to a bench would make life easier but it's not required.
Re: stainless trim polishing [Re: TrueTripleX] #3093523
11/11/22 07:07 PM
11/11/22 07:07 PM
A727Tflite Offline
A727Tflite  Offline
If no repairs are needed - look up Eastwood’s website for rouge, etc. I did.
I did mine and they came out looking new.
Re: stainless trim polishing [Re: burdar] #3094350
11/15/22 12:55 PM
11/15/22 12:55 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I have a separate dedicated polisher with two different pads on it. It's mounted to a couple heavy blocks of wood and somewhat easy to move around. If the weather is nice, I do it outside. Otherwise, you need to build a cage of some sort out of plastic or cardboard, because you will make a mess.
I've done some aluminum as well. I've taken the anodize off a few pieces (purposely). It does require some routine maintenance, but it's not bad. Something that would see weather more often than not, I would have re-anodized.
Re: stainless trim polishing [Re: sixpakdodge] #3094645
11/16/22 01:07 PM
11/16/22 01:07 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
It is not hard to polish stainless trim. It just takes time and patients. I use my bench grinder and purchased an expander wheel and buffing wheels etc. from a vendor at Carlisle. I've done several cars and they came out great.
Re: stainless trim polishing [Re: 57Fury440] #3094678
11/16/22 02:04 PM
11/16/22 02:04 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I got a free large Baldor buffer years ago, went to plug it in and found out it was three phase so I never got around to getting a converter, but would love to use it one day... luck
JB Rhinehart, Realist
A-Body's RULE!
Re: stainless trim polishing [Re: Rhinodart] #3094923
11/17/22 11:42 AM
11/17/22 11:42 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
biggest thing with polishing stainless is to know that the polisher is the last part of the job. whole lot of sanding first. 600-800-1200-1800 grit then polish. if not you have just semi shiny stainless with scratches.
Re: stainless trim polishing [Re: Rhinodart] #3094997
11/17/22 03:01 PM
11/17/22 03:01 PM
You can have it rewired for your house current or use another smaller regular electric motor to make 3 phase scope
One of the guys who use to work for me did that on a big 3 phase lathe that he bought to use at home wrench
Re: stainless trim polishing [Re: Cab_Burge] #3095270
11/18/22 03:59 PM
11/18/22 03:59 PM
moparx Offline
moparx  Offline
i don't know if this will work on your 3phase buffer, but my buddy found out he could get his surface grinder working by wrapping a rope around the output shaft and pulling, starting it like a lawn mower. biggrin
beer
Re: stainless trim polishing [Re: TrueTripleX] #3095618
11/19/22 08:57 PM
11/19/22 08:57 PM
robertop Offline
robertop  Offline
I am in Marietta. At this moment I am not very mobile ( badly twisted ankle ), but, if you can manage to get here, I will show you the trim I did on my 69 roadrunner and I will help with some good advice. Don’t worry about money!
