Re: 563 Dyno results
[Re: 440Jim]
#3089825
10/28/22 09:15 AM
10/28/22 09:15 AM
Posts: 10,050 MN
JERICOGTX
MN
Nice to see the results after all the delays. Very good post with combo summary and dyno results all in one place.
733.0 ft-lbs at 5700 rpm 869.8 hp at 7000 rpm
I bet it would hold close to that HP at higher RPM. I was asked how high I was willing to spin it, and told him I didn’t want to go over 7000, and would most likely be shifting it at 6800. It’s a bracket engine. I want it to last a long time.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3089848
10/28/22 10:14 AM
10/28/22 10:14 AM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Glad to see you worked thru the issues and got it done. Nice numbers!! Looking forward to the track results next spring.
[Re: fast68plymouth]
#3089852
10/28/22 10:27 AM
10/28/22 10:27 AM
Posts: 10,050 MN
JERICOGTX
MN
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Glad to see you worked thru the issues and got it done. Nice numbers!! Looking forward to the track results next spring. Thanks Dwayne! And thank you for setting up a great set of heads.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3089857
10/28/22 10:49 AM
10/28/22 10:49 AM
Posts: 7,500 Minnesota
Hemi_Joel
Minnesota
Congrats on the successful dyno runs. That should put you in the 9 teens or oh's. You say you just want it to get down the track, hang out with your friends at the dragstrip. I know better. You want an 8 second time slip! What is it going to take, 8.86?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3089868
10/28/22 11:22 AM
10/28/22 11:22 AM
Posts: 4,715 Wichita
GY3
Wichita
Very impressive and such a clean looking engine!
[Re: Hemi_Joel]
#3089869
10/28/22 11:27 AM
10/28/22 11:27 AM
Posts: 10,050 MN
JERICOGTX
MN
Congrats on the successful dyno runs. That should put you in the 9 teens or oh's. You say you just want it to get down the track, hang out with your friends at the dragstrip. I know better. You want an 8 second time slip! What is it going to take, 8.86? Wallace calculator shows it “should run 8.85 @ 152 mph. But we all know that is with optimum conditions, and sea level. We don’t race at either of those. While yes, I’d love to see a 8.9999 before the 4th of July, and collect yet another dinner from you, I’ll be content with a 9.teen, and have it repeat all day.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3089875
10/28/22 12:11 PM
10/28/22 12:11 PM
Posts: 4,702 On the parachute mount
n20mstr
Congrats on the successful dyno runs. That should put you in the 9 teens or oh's. You say you just want it to get down the track, hang out with your friends at the dragstrip. I know better. You want an 8 second time slip! What is it going to take, 8.86? Wallace calculator shows it “should run 8.85 @ 152 mph. But we all know that is with optimum conditions, and sea level. We don’t race at either of those. While yes, I’d love to see a 8.9999 before the 4th of July, and collect yet another dinner from you, I’ll be content with a 9.teen, and have it repeat all day. If you want to run in the 8's ....its practically a no brainer. SLip the "correct" carb spacer ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) in there and im sure it will go DEEP into the 8's ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Seriously.....congrats, that a bad A$$ bracket engine ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
....BAD A$$ STREET CAR.....
[Re: second 70]
#3089901
10/28/22 01:12 PM
10/28/22 01:12 PM
Posts: 19,400 Las Vegas
Al_Alguire
Las Vegas
Sounds like a runner, dont see why you cannot get her into the 8's with that piece. As for carb spacers, ehh. I have dynoed alot of engines and seems you can stack them to the ceiling and make more power and put it in the car and see ZERO gains. Its all about plenum volume for the given combo, if its good its good. FWIW we have had the best luck with the ones we have made for our stuff to match the carb size more than a generic spacer. I believe that is do more to fuel shear atomization and droplet size than anything else.
[Re: Al_Alguire]
#3089964
10/28/22 04:19 PM
10/28/22 04:19 PM
n20mstr
Sounds like a runner, dont see why you cannot get her into the 8's with that piece. As for carb spacers, ehh. I have dynoed alot of engines and seems you can stack them to the ceiling and make more power and put it in the car and see ZERO gains. Its all about plenum volume for the given combo, if its good its good. FWIW we have had the best luck with the ones we have made for our stuff to match the carb size more than a generic spacer. I believe that is do more to fuel shear atomization and droplet size than anything else. Al , these carb spacers work wonders , and only one needed 😂
[Re: n20mstr]
#3089967
10/28/22 04:32 PM
10/28/22 04:32 PM
GY3
Wichita
Sounds like a runner, dont see why you cannot get her into the 8's with that piece. As for carb spacers, ehh. I have dynoed alot of engines and seems you can stack them to the ceiling and make more power and put it in the car and see ZERO gains. Its all about plenum volume for the given combo, if its good its good. FWIW we have had the best luck with the ones we have made for our stuff to match the carb size more than a generic spacer. I believe that is do more to fuel shear atomization and droplet size than anything else. Al , these carb spacers work wonders , and only one needed 😂 I have one of those with the lettering blacked out. It has a hot side and a cold side.... ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: JERICOGTX]
#3089978
10/28/22 05:08 PM
10/28/22 05:08 PM
Posts: 43,364 Bend,OR USA
Cab_Burge
Did you try making any pulls with the air sensor disconnected and remove with the carb open to the room air only? If so what was the differences? If not ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: Cab_Burge]
#3089984
10/28/22 05:27 PM
10/28/22 05:27 PM
Posts: 20,228 Park Forest, IL
slantzilla
Park Forest, IL
Congratulations Jeff! Can't wait to see what it does in the car.
[Re: JERICOGTX]
#3089989
10/28/22 05:59 PM
10/28/22 05:59 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Nice job to all involved. That car is going to run just as good as it looks!
Rich H.
Esse Quam Videri
