What's your preferred brand or style of collector gaskets? #3089225
10/25/22 10:31 PM
10/25/22 10:31 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
wink
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: What's your preferred brand or style of collector gaskets? [Re: Brad_Haak] #3089234
10/26/22 01:10 AM
10/26/22 01:10 AM
No gaskets preferred, slip on male and female for me up
Re: What's your preferred brand or style of collector gaskets? [Re: Cab_Burge] #3089262
10/26/22 05:28 AM
10/26/22 05:28 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
V bands
Re: What's your preferred brand or style of collector gaskets? [Re: FastmOp] #3089265
10/26/22 06:22 AM
10/26/22 06:22 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Ive heard good things about Remflex. Haven't tried them yet.
Re: What's your preferred brand or style of collector gaskets? [Re: MI_Custumz] #3089267
10/26/22 06:29 AM
10/26/22 06:29 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Starting from scratch I would weld V bands on the collectors. I won't do an exhaust system without those ever again. I put some V bands in my exhaust so my mid pipe can be removed for transmission work. I bought some from Amazon and they have worked really well.
For real collector and header gaskets I like whatever TTI sells, I have never had a problem with them. My collector gaskets have been reused many many many times.
68 Barracuda Formula S 340
Re: What's your preferred brand or style of collector gaskets? [Re: Bad340fish] #3089273
10/26/22 08:07 AM
10/26/22 08:07 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I have Remflex 2.5" gaskets throughout my exhaust system, about 6 points with Stainless 1/2" flanges, no leaks even 10 years later. I bought the header versions too because they are amazing but haven't installed them
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: What's your preferred brand or style of collector gaskets? [Re: Pyper70] #3089283
10/26/22 08:48 AM
10/26/22 08:48 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I tried remflex , copper,the old plain gasket type & so far the aluminum ones have been in there a long time & still good.
Re: What's your preferred brand or style of collector gaskets? [Re: CSK] #3089311
10/26/22 10:26 AM
10/26/22 10:26 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Haven't had an issue in decades, even with the old whitish fiber gaskets, but the flanges have to be aligned & flat.
Re: What's your preferred brand or style of collector gaskets? [Re: Bad340fish] #3089322
10/26/22 10:52 AM
10/26/22 10:52 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I'm building the 4" for my Ram with V bands so I can get the down pipe out to making pulling the trans easier if and when I have to do it .
I also built a multi piece headpipe for the Dart and I'm going to switch it to these for the same reason , doing a clutch
Re: What's your preferred brand or style of collector gaskets? [Re: Cab_Burge] #3089347
10/26/22 12:38 PM
10/26/22 12:38 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I too have a slip on at the collector, but I have a leak there because it is not a tight fit. I think a band clamp will fix it.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What's your preferred brand or style of collector gaskets? [Re: Brad_Haak] #3089355
10/26/22 12:46 PM
10/26/22 12:46 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The Mr. Gasket CopperSeal Gaskets - they are made from dead soft copper and reusable - I have used these for years - well worth the price
Re: What's your preferred brand or style of collector gaskets? [Re: DoubleD] #3089432
10/26/22 04:34 PM
10/26/22 04:34 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Any cheap gasket will do if the mating surfaces are straight. A tiny smear of copper rtv helps if you still have issues. Copper gaskets combined with a little copper rtv is popular among racers as it's strong and re-usable over and over.
If you blow gaskets all the time you have a parts problem more than a gasket problem.
Re: What's your preferred brand or style of collector gaskets? [Re: Neil] #3089471
10/26/22 06:57 PM
10/26/22 06:57 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've used the aluminum gaskets for years. up
Re: What's your preferred brand or style of collector gaskets? [Re: CSK] #3089478
10/26/22 07:11 PM
10/26/22 07:11 PM
Loudoun County, VA
Loudoun County, VA
I found a couple pair of "dead soft" aluminum ones from Summit in my collector parts box this afternoon. Never run them before... IIRC I was using Mr. Gasket Ultra Seals the last time.
This is an existing TTI system, so no conversion to gasket-less joints w/ v-bands. However, I'm adding a second set of collector hookups between the mufflers and the tail pipes so I can drop the exhaust between the headers and the tail pipes to make trans maintenance (primarily) easier.
I'm also changing the collector config from the headers to use Flowmaster 3.50" to 3.0" tapered collector extensions, instead of the standard short TTI 3.5" to 3.0" collector reducer. It might not make a noticeable difference, but we saw some loss of torque when a straight 3.5" x 18" collector extension was tested vs a standard short 3.5 to 3.0 collector reducer with an 3.0" x 18" collector extension. Torque curve comparison attached below.
Re: What's your preferred brand or style of collector gaskets? [Re: Brad_Haak] #3089479
10/26/22 07:14 PM
10/26/22 07:14 PM
Loudoun County, VA
Loudoun County, VA
Exhaust system in driveway getting ready for re-installation
Re: What's your preferred brand or style of collector gaskets? [Re: Brad_Haak] #3089480
10/26/22 07:16 PM
10/26/22 07:16 PM
Some dyno testing doesn't lead you in the best way unless you follow up by testing at the track also shruggy work
Been down that road more than once, the time slip and spark plug are your best tuning aids and information gathering tools up twocents
Re: What's your preferred brand or style of collector gaskets? [Re: Brad_Haak] #3089481
10/26/22 07:16 PM
10/26/22 07:16 PM
Loudoun County, VA
Loudoun County, VA
Closer view of Flowmaster 3.50" to 3.0" tapered collector extensions and standard short TTI 3.5" to 3.0" collector reducer that feeds into 3.0" x-pipe system.
Re: What's your preferred brand or style of collector gaskets? [Re: Brad_Haak] #3089493
10/26/22 08:01 PM
10/26/22 08:01 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Dead soft aluminum. Try them, they work great.
Re: What's your preferred brand or style of collector gaskets? [Re: GTX MATT] #3089637
10/27/22 12:56 PM
10/27/22 12:56 PM
an8sec70cuda Offline
I have used the aluminum collector gaskets and they've always worked great. I have a set that's probably 15 years old on my dad's road runner. Been apart several times, still no leaks.
On my cuda I used the conventional flat fiber style gaskets that came w/ the TTI headers. I coated them in antiseize and installed them. They're still leak free since 2006, BUT THEY'VE NEVER BEEN APART. My exhaust system uses a flat band style connection, so I never have to unbolt the collector.
Those newer V band clamps look like the hot ticket if you're building something new.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What's your preferred brand or style of collector gaskets? [Re: an8sec70cuda] #3089638
10/27/22 01:01 PM
10/27/22 01:01 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Jegs house brand copper collector gaskets have always worked well for me and been reusable.
V bands are the way to go if building new, though.
Rich H.
Esse Quam Videri
