What's your preferred brand or style of collector gaskets?
#3089225
10/25/22 10:31 PM
10/25/22 10:31 PM
Posts: 1,185 Loudoun County, VA
Brad_Haak
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: What's your preferred brand or style of collector gaskets?
[Re: MI_Custumz]
#3089267
10/26/22 06:29 AM
10/26/22 06:29 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Starting from scratch I would weld V bands on the collectors. I won't do an exhaust system without those ever again. I put some V bands in my exhaust so my mid pipe can be removed for transmission work. I bought some from Amazon and they have worked really well.
For real collector and header gaskets I like whatever TTI sells, I have never had a problem with them. My collector gaskets have been reused many many many times.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3089273
10/26/22 08:07 AM
10/26/22 08:07 AM
Posts: 5,911 Athens, Greece
Pyper70
Athens, Greece
I have Remflex 2.5" gaskets throughout my exhaust system, about 6 points with Stainless 1/2" flanges, no leaks even 10 years later. I bought the header versions too because they are amazing but haven't installed them
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#3089283
10/26/22 08:48 AM
10/26/22 08:48 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I tried remflex , copper,the old plain gasket type & so far the aluminum ones have been in there a long time & still good.
[Re: Bad340fish]
#3089322
10/26/22 10:52 AM
10/26/22 10:52 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
For real collector and header gaskets I like whatever TTI sells, I have never had a problem with them. My collector gaskets have been reused many many many times. I'm building the 4" for my Ram with V bands so I can get the down pipe out to making pulling the trans easier if and when I have to do it . I also built a multi piece headpipe for the Dart and I'm going to switch it to these for the same reason , doing a clutch
[Re: Cab_Burge]
#3089347
10/26/22 12:38 PM
10/26/22 12:38 PM
Posts: 16,546 On the run…
BloFish
On the run…
No gaskets preferred, slip on male and female for me I too have a slip on at the collector, but I have a leak there because it is not a tight fit. I think a band clamp will fix it.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: CSK]
#3089478
10/26/22 07:11 PM
10/26/22 07:11 PM
Brad_Haak
Loudoun County, VA
I tried remflex , copper,the old plain gasket type & so far the aluminum ones have been in there a long time & still good. I found a couple pair of "dead soft" aluminum ones from Summit in my collector parts box this afternoon. Never run them before... IIRC I was using Mr. Gasket Ultra Seals the last time. This is an existing TTI system, so no conversion to gasket-less joints w/ v-bands. However, I'm adding a second set of collector hookups between the mufflers and the tail pipes so I can drop the exhaust between the headers and the tail pipes to make trans maintenance (primarily) easier. I'm also changing the collector config from the headers to use Flowmaster 3.50" to 3.0" tapered collector extensions, instead of the standard short TTI 3.5" to 3.0" collector reducer. It might not make a noticeable difference, but we saw some loss of torque when a straight 3.5" x 18" collector extension was tested vs a standard short 3.5 to 3.0 collector reducer with an 3.0" x 18" collector extension. Torque curve comparison attached below.
[Re: Brad_Haak]
#3089479
10/26/22 07:14 PM
10/26/22 07:14 PM
Brad_Haak
Loudoun County, VA
Exhaust system in driveway getting ready for re-installation
[Re: Brad_Haak]
#3089481
10/26/22 07:16 PM
10/26/22 07:16 PM
Brad_Haak
Loudoun County, VA
Closer view of Flowmaster 3.50" to 3.0" tapered collector extensions and standard short TTI 3.5" to 3.0" collector reducer that feeds into 3.0" x-pipe system.
[Re: Brad_Haak]
#3089493
10/26/22 08:01 PM
10/26/22 08:01 PM
Posts: 5,167 CT
GTX MATT
CT
Dead soft aluminum. Try them, they work great.
[Re: GTX MATT]
#3089637
10/27/22 12:56 PM
10/27/22 12:56 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I have used the aluminum collector gaskets and they've always worked great. I have a set that's probably 15 years old on my dad's road runner. Been apart several times, still no leaks.
On my cuda I used the conventional flat fiber style gaskets that came w/ the TTI headers. I coated them in antiseize and installed them. They're still leak free since 2006, BUT THEY'VE NEVER BEEN APART. My exhaust system uses a flat band style connection, so I never have to unbolt the collector.
Those newer V band clamps look like the hot ticket if you're building something new.
[Re: an8sec70cuda]
#3089638
10/27/22 01:01 PM
10/27/22 01:01 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
Jegs house brand copper collector gaskets have always worked well for me and been reusable.
V bands are the way to go if building new, though.
Rich H.
Esse Quam Videri
