Interesting article on piston ring tech #3089397
10/26/22 03:03 PM
10/26/22 03:03 PM
Out of the State of Confusion
blue_stocker Offline OP
I get these almost daily and sometimes they open my eyes to things that might or even will yield positive results with HP building and efficiency...check it out!
https://www.enginelabs.com/news/what-i-learned-today-standard-oil-ring-tension-isnt-standard/
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Interesting article on piston ring tech [Re: blue_stocker] #3089418
10/26/22 03:39 PM
10/26/22 03:39 PM
NC
440Jim Offline
440Jim  Offline
NC
Quote
What’s interesting is that what was considered “standard” tension for an oil ring for a street engine has changed significantly in the last 20 years. If you look at the accompanying chart, you can see that the tension produced by the older 3/16-inch oil rings used in a 1/16-, 1/16-, 3/16-inch ring package is fairly high at 20 lbf. The slightly smaller 3.0mm ring package used in a 2000-era LS1 for example is rated at only 10 lbf.
Lots of subtle things about ring packages. Gas porting, vacuum pump use, thin, thick, etc.
Use of Napier "scraper" second ring with lower tension oil ring...
And one company's "std" oil ring tension is different from another... and maybe even different then that company used 15 years ago.
