Re: Bore out lifter bores to .937 ? [Re: DracerX] #3252128
08/17/24 08:29 PM
08/17/24 08:29 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
RacerX,
No I have not yet, shows you how fast I make progress. But I have not abandoned this train of thought at all !
The large oil galley opening for the lifter could possibly be worked around.
It would involve restricting certain oil galleys and possibly re-routing high pressure oil with steel tubing.
Or, use some kind of full skirt lifter.
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3252129
08/17/24 08:40 PM
08/17/24 08:40 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
On a production block and typical moderate 'race' application a 1" OD bushing installed with about .0015" press and 'trued' has been the standard reliable practice for eons. Put an .043 hole in it and oversize the oil feed hole at the turn being cautious of the material being left on the gallery wall. It solves oil control issues and properly done it trues-up cam timing variation. Plenty of higher quality .904 bodied lifters available. ADDING: while you're there make the bushing as long as possible.
Re: Bore out lifter bores to .937 ? [Re: HardcoreB] #3252202
08/18/24 10:11 AM
08/18/24 10:11 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have done .937" lifters with bronze bushing MANY times with Mopar BB's. GThere is no issue with it. Depending on the lifters you can get a larger wheel on that body. I use Jesel lifters FWIW
Re: Bore out lifter bores to .937 ? [Re: Al_Alguire] #3252251
08/18/24 12:08 PM
08/18/24 12:08 PM
I've had several stock B and RB blocks bushed for the 904 lifters and use the .820 solid roller wheel lifters, worked good up
Re: Bore out lifter bores to .937 ? [Re: Cab_Burge] #3252260
08/18/24 12:51 PM
08/18/24 12:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A .937" lifter allows you to go to an .850" wheel....A 1.062" lifter would allow for up to a .940" wheel. The larger lifter body also allows for a larger pushrod to be used.
Re: Bore out lifter bores to .937 ? [Re: Al_Alguire] #3252261
08/18/24 12:57 PM
08/18/24 12:57 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Hello Al,
Are the bushings, at least for Mopar, 1/16" wall thickness, meaning that the OD is 1 1/16 for a .937 lifter ?
My only objection is that a 1 1/16 bushing leaves very little metal left on the existing lifter bore.
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3252291
08/18/24 04:09 PM
08/18/24 04:09 PM
fredericksburg,va
cudaman1969 Online sleepy
Itch Nutz
cudaman1969  Online Sleepy
Itch Nutz
fredericksburg,va
Why not make a lifter girdle with bushing protruding up thru it. Then fill in around the gally outside with epoxy or similar substance? Like hardblock does for cylinders.
Re: Bore out lifter bores to .937 ? [Re: cudaman1969] #3252321
08/18/24 08:02 PM
08/18/24 08:02 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
That is an outstanding idea !
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3252393
08/19/24 07:32 AM
08/19/24 07:32 AM
gregsdart Offline
gregsdart  Offline
Novice question here. Since power expected is modeate at 650 hp out of 500+ cubes, why not consider a STEP BACKWARDS? The thought comes to mind that the bbc motor uses a smaller lifter for power levels above what you seek. If a block needs repair work, total cost would also include the added (if any) cost of special size lifters. I am assuming hi quality bbc roller lifters would be cheaper, and readily available should you ever need a replacement. At 650 reqiured power level, a rather mild roller profile and modest springs will make for a long life motor.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Bore out lifter bores to .937 ? [Re: gregsdart] #3252400
08/19/24 07:59 AM
08/19/24 07:59 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Not a bad idea BUT ... you can't just take a Mopar roller cam and run it with Chevy-sized rollers and expect the same results. The specs will change everywhere in the cycle except at the baseline and max lift. You would need to have a cam ground on a Mopar blank with a Chevy profile to accomodates the different size lifter wheels.
Re: Bore out lifter bores to .937 ? [Re: Stanton] #3252413
08/19/24 09:03 AM
08/19/24 09:03 AM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
I would think yea on a flat tappet lifter but a roller is always dead center touching the cam no matter how big it is. Like train wheels could be 6 ft in diameter but only touch’s the rail a couple thousands of an inch. Maybe I’m thinking this wrong but..
Re: Bore out lifter bores to .937 ? [Re: cudaman1969] #3259918
09/25/24 03:31 AM
09/25/24 03:31 AM
DracerX Offline
DracerX  Offline
With a flat tappet, the contact point and pressure angle doesn't change when going up in lifter diameter. A larger diameter does let you run more aggressive lobes without the contact point getting too close to the edge of the lifter.
With larger diameter roller wheels, the pressure angle is reduced, and the wheel makes contact with the ramp of the profile earlier. There is also less side loading at the bottom of the lifter.
Cam grinders can alter the lobe profile to produce the same valve motion regardless of wheel size, if you tell them the diameter wheels you are using. Otherwise, you will add a degree or more to the duration running a larger wheel than the lobe was ground for. Total lift remains unchanged.
https://www.motortrend.com/features/hot-rod-shop-series-march-1980-982-1146-72-1/
https://www.motortrend.com/uploads/...8&width=768&q=75&format=webp
Re: Bore out lifter bores to .937 ? [Re: DracerX] #3259946
09/25/24 09:04 AM
09/25/24 09:04 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Originally Posted by DracerX
hemienvy, did you go down the .937 lifter path? Does anyone else here have experience doing this?
I've got a B block 512 going together and the factory bores are 0.9063 to 0.9071.
Many of them have taper top to bottom and slightly out of round.
I've heard, but have not been able to confirm, that BAM will make oversize on request.
I'd have to have the lifter bores trued up anyhow so why not go to an off the shelf size versus custom.
This is a street/strip build to hit about 650 HP, solid roller cam.
I like the idea of not removing so much metal to fit a bushing.
Would plan on using a lifter with edge orifice oiling with the hole parallel to the oil galley.
I can set up the block for full time oiling with modified passages, or go with PR oiling.
Mopar used to offer oversize lifters (like maybe .005" & .010" oversize) which would be very helpful to us right now.
2011 Drag Pak Challenger
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3259997
09/25/24 11:33 AM
09/25/24 11:33 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
just rambling......
Money versus gain came into my equation awhile back. I considered going to Ford or Chevy size .875 solid flat lifters because they are hundreds less and everywhere. NASCAR lifters can be resurfaced and are super hard. I think that's a good option for lower HP engines. But anyhow, I bushed them back to stock spec..
I had a couple sets of $1700 Jesel .937 lifters for a B-1 engine that never got finished and I think I have one set left?
:Project 2025, America's elite Mein Kampf
