Originally Posted by Hemi_Joel
For street use, if you go with a solid roller, it is important to go with a lifter that has pressure oiling to the roller axle. Do not us a splash lube roller lifter, it is very likely that you will have problems if you do.
Also, the bushed lifters are pretty tuff, and there are no needles to fail.
That makes sense, thanks. What do most of the drag week guys use for their builds? Bushed solid roller lifters? Clark, are you running bushed or needle bearing lifters in yours?
