Major electrical short #3086189
10/15/22 10:34 AM
10/15/22 10:34 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I must have a short to the chassis from a chafing rub through a frame or back seat blockoff and will hunt it down.The short melted a 0g copper lug to the - battery post and put a hole in the battery case from the heat too close.I could use a better battery connector to the post but part of the problem was this was not tight on the post and was no help to the ground.
Re: Major electrical short [Re: Clanton] #3086193
10/15/22 10:43 AM
10/15/22 10:43 AM
BDW Online content
BDW  Online Content
Always worried about this, how did you know it happened? Car wouldn't start and traced it down.?
With most new cars having the battery in trunk, what's that safety mechanism.
What happens if they cables hold up, battery explodes?
Re: Major electrical short [Re: BDW] #3086202
10/15/22 10:58 AM
10/15/22 10:58 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I just drove the car and when I parked it all power went out and I tested for + at the switch panel and a ground with a test light so I made a new ground for the switches and it smoked the 02 power wire like a wick on a firecracker so I undo the ground and go to the battery and find the chassis ground cable barely hanging on the the connector at the post.This could have been really bad and the weak link was the connector.I do have a 200 amp breaker to the switch panel .I believe the broblem is in the starter wire or the switch breaker would have went. I have a volt meter and there was no drop in voltage I could see.
Re: Major electrical short [Re: Clanton] #3086221
10/15/22 11:46 AM
10/15/22 11:46 AM
Andrewh Offline
Andrewh  Offline
thought that the connector going first was the whole point?
I had one that melted it off the battery first before anything else burned off.
I have also had a short vaporize an inch of 10 gauge. plus a couple inches of insulation on each side.
Re: Major electrical short [Re: Andrewh] #3086224
10/15/22 12:00 PM
10/15/22 12:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Only time I've been able to accomplish that was when a battery + cable grounded.
It was a wheelstand that hit the charging post bracket under the rear bumper.
Somehow it didn't kill the batteries or charging system, but it melted the charging cables.
Re: Major electrical short [Re: Andrewh] #3086257
10/15/22 01:35 PM
10/15/22 01:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Lets say the connector burns so then the cable is flopping around looking for more trouble what can you do but have a bracket holding the cable or a tether.
Re: Major electrical short [Re: Clanton] #3086295
10/15/22 03:19 PM
10/15/22 03:19 PM
moparx Offline
moparx  Offline
how was that battery cable end attached to the cable ?
solder ?
i know it got hot there, but for some reason, the joint doesn't look it was soldered very good. i know my eyeballs aren't the best, but even if it got hot enough to melt the solder, the wire of the cable should at least show some silver in the middle strands.
a while back, i bought a hydraulic cable crimper. i now crimp the cable connection after the cable has been tinned with solder, and the connector has flux in it.
i drill a small 1/8" [or so] hole in the bottom of the connector, then use that hole to allow the solder to wick into the joint, watching the top of the connector, so as to not allow the solder to wick into the cable past the connector end.
i then use marine grade heat shrink with the glue in the "heavy duty" size [which is twice as thick as the regular stuff] to cover the cable/connector area.
please let us know what you find out in that length of cable, as to the place it shorted out.
beer
Re: Major electrical short [Re: Clanton] #3086296
10/15/22 03:20 PM
10/15/22 03:20 PM
Maryland
MoparMike1974 Offline
Maryland
It could be a short but it could also simply had been a bad connection on that terminal. This will cause an excessive draw and cause it to get hot.
Like the above poster, I also use a hydraulic crimper. This is just as good as a molded terminal. I spend the extra money and get the nice brass terminals.
Re: Major electrical short [Re: Clanton] #3086580
10/16/22 05:20 PM
10/16/22 05:20 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Found the problem!The starter wire hung down on the muffler that is tight to the rocker panel where I ran the wire next to the brake line so after putting in new wire I will cover,secure things better.
Re: Major electrical short [Re: Clanton] #3086655
10/16/22 09:08 PM
10/16/22 09:08 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Stuff like that happens.
When I built my 48 Plymouth coupe I ran all the battery cables and wires where I thought they would be out of trouble. Then I added inner fender wells to keep the junk out of the engine compartment.
What I didn't know was when the tires were turned to the extreme right, the tire rubbed against the inner fender, and squeezed the + battery cable between the battery box brace and the inner fender. It took over 5 years before it finally broke through the battery cable insulation and shorted out the positive battery cable. The little fire was out as soon as the cable was disconnected, but I got to replace the battery cable, and about 6" of 3 other wires. You can bet the wires were run differently, and secured better.
Re: Major electrical short [Re: Clanton] #3086674
10/16/22 10:07 PM
10/16/22 10:07 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
thanks for the Update up
Re: Major electrical short [Re: Clanton] #3086682
10/16/22 10:30 PM
10/16/22 10:30 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Mike you really need to get a better quality battery terminal on there.
. You might want to replace that cable because where it has tuned black will not conduct very well.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Major electrical short [Re: fourgearsavoy] #3086886
10/17/22 03:30 PM
10/17/22 03:30 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Gus beer
I had some better[brass] terminals on my winch battery I swapped but I will get some more and you are very correct on the cable being black and I will make a new 1 with fresh wire.How big should I go on the mini starter cable with 2xyellow top 750 amp batteries?[12' long maybe]
Re: Major electrical short [Re: poorboy] #3086890
10/17/22 03:37 PM
10/17/22 03:37 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
That could have been a real problem if you didn't have any tools when it happened.Thanks for sharing!
Re: Major electrical short [Re: Clanton] #3086899
10/17/22 04:07 PM
10/17/22 04:07 PM
IMGTX Offline
IMGTX  Offline
A similar thing happened to me a long time ago. Starter came loose during a race. Went to crank it later and POOF!
The only thing that saved me from severe damage was the negative battery cable to the chassis at the rear of the car was 2 sizes smaller than the positive. The negative cable popped like a fuse. Positive cable was fine. If they were the same size i could have easily lit up the positive cable running all the way to the front of the car.
I always tell people to make the negative wire smaller and you would think I told them to drop in a Ford 289 instead of a HEMI. If both are the same size the then the load during a short can cause both wires to melt and be devastating.
I bolted the starter back into place and replaced the negative cable. Back in business in less than 5 minutes.
Glad you didn't have anything worse happen.
Re: Major electrical short [Re: IMGTX] #3086925
10/17/22 06:16 PM
10/17/22 06:16 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Glad thing worked out.I have a +0 cable for the starter I got last fall to upgrade and I had a 4g ground on the battery not a 0g like I thought so I will go with the 4g again,ty
Re: Major electrical short [Re: Clanton] #3086953
10/17/22 07:21 PM
10/17/22 07:21 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I now put a 120 amp fuse at the alternator and one at the battery. Forget size but I think it’s a 300 amp or so. Protects against these types of conditions.
Re: Major electrical short [Re: markz528] #3086963
10/17/22 08:00 PM
10/17/22 08:00 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Just not on the starter cable? I need all the amps I can get for the starter.
Re: Major electrical short [Re: Clanton] #3086971
10/17/22 08:27 PM
10/17/22 08:27 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have a 250 275 or 300 on the main battery cable I just can’t remember right not. I will post pics tomorrow.
With a fuse on the alt I’m protected from both ends no matter what happens.
Re: Major electrical short [Re: Clanton] #3087316
10/18/22 10:31 PM
10/18/22 10:31 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
So I did use a 300 amp on the main cable.
