Re: "Detonation problems" rebuild 440-6
[Re: 70sixpkrt]
#308642
05/07/09 02:41 AM
05/07/09 02:41 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I am using 65 jet in the center and 80s on all 4 corners.
#80 jets have a .093 orifice...
So if you were to start with a .085 pin drill & creep up from there...
[Re: Mr.Yuck]
#308656
05/08/09 02:06 PM
05/08/09 02:06 PM
Posts: 108 Sweden
6pakdude
Sweden
Removed the fuel bowl for the front carb, the metering plate (34R-9716B) had about 0,0910" drill size, jet 81. So I left it as it was.
Removed the rear carb, the metering plate(34R-5113B) had about 0,0870# drill size, jet 78.
Checked the org plate stamped 35, driver side about 0,0910" drill sze, pass side about 0,0870" drill size.both were the same.
So I took one org 35 plate drilled it 0,0910" and mounted it in the rear carb. jet size 81.
so all 4 has about 81 jet size now.
Distributor 16 intial total 30 w vacum.
Took the car for a test drive (heavy after work traffic fridays) well I got a couple of chances to try it out. Going in second at 2000rpm and floored it, could take up to 5400RPM in second, later tried rolling slowly 1 st gear and floor it, 5500rpm, shift manually to second and 5400RPM, to much traffic to try 3 gear.
But at 5500RPM I got that sound I called detonation, perhaps thats the wrong name for the problem.running lean.
So more gas helped bring the RPM up another600-700 RPM.
Thinking of go from 64 to 66 in the center carb, what you thoughts on doing that. maybe to much? but I think the engine wants more gas to bring up tp 6000RPM and try without vacum, maybe have 2-4 degree more total timing. No pinging today.
PW 65, outboards open fully
Bought new colder plugs Accel 124, havn't put them in yet.
So its slowly getting there.
[Re: Classof70Chally]
#308658
05/08/09 04:13 PM
05/08/09 04:13 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
You are going in the right direction. What ignition are you using? I am using the MSD Pro Billet Dist. set at 14* initial timing and 35* total. Stay at it and you will get it. Oh never mind. I see you are using a stock dual point with Petronix. I have heard some people say they have had problems with Petronix.
[Re: 70sixpkrt]
#308659
05/09/09 03:31 AM
05/09/09 03:31 AM
Posts: 108 Sweden
6pakdude
Sweden
Have had no problems with the Pertronix since installed 2004. Running a stock dated coil (repro) with Pertronix black plug wires. Have a set of repro dated wires waiting to go on, but have read they are no good My 70 Challenger R/T is a match # car, try to keep everything as original as possible. These cars run good when new (after some updating) and they should run as good today. Did you use Promax Throttle plate on your rear carb, with the jet plates. ![](/ubbthreads/images/graemlins/drive.gif) Concernig the fuel 98 we have here in SWEDEN, It's what you call 92 in the U.S.A. We have someting sold by Shell called v-power, and it's the same as your 93 premium.
