318 engine cooling fan non-clutch where can I get one? #308442
05/05/09 09:37 AM
05/05/09 09:37 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Looking for a cooling fan for a 318 1974 ci engine. Cannot find a direct replacement, anyone know where I can get a new one. Everthing I found on-line has a clutch/viscous combo. I'm going to start calling junk yards. Rather have new though.
Thanks.
Re: 318 engine cooling fan non-clutch where can I get one? [Re: cudabitten] #308443
05/05/09 10:58 AM
05/05/09 10:58 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why not just get n standard Mopar fan and a spacer.
Re: 318 engine cooling fan non-clutch where can I get one? [Re: cudabitten] #308444
05/05/09 11:17 AM
05/05/09 11:17 AM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
Both flex-a-lite and derale make universal rigid fans that should work for you.
Re: 318 engine cooling fan non-clutch where can I get one? [Re: JeffC] #308445
05/05/09 05:00 PM
05/05/09 05:00 PM
scratchnfotraction Offline
look for one on a /6 engine and get the space the right size
some older trucks vans have a direct drive fan blade
I went from a 4 blade on mine to a 7 blade direct drive fan
you can get the spacer at the auto store with the bolts
hit the JY and look around,I used a 7 blade fan off a amc hornet also
Re: 318 engine cooling fan non-clutch where can I get one? [Re: scratchnfotraction] #308446
05/05/09 07:46 PM
05/05/09 07:46 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Shouldn't be that hard to find a fan that fits. All are pretty much interchangable other than the ones mounting on the back side of the clutch which require the large center hole and larger mounting spacing.
Re: 318 engine cooling fan non-clutch where can I get one? [Re: MoparforLife] #308447
05/05/09 08:01 PM
05/05/09 08:01 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
They used that setup past 74 my 78 Fury Sport (also 318) with factiry AC also has the 4 blade solid fan. Might help knowing that you can broaden your search a bit.
