Re: 727 Accumulator Spring Question
[Re: 6PAX]
#3083591
10/05/22 03:47 PM
10/05/22 03:47 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
If you pull the spring you should install a blocker rod . Me personally, street car I'd leave the spring in. If you want a real hard shift leave it out, it only affects one shift
[Re: 6PAX]
#3083646
10/05/22 07:42 PM
10/05/22 07:42 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
With a loose converter I would remove the spring and block it down. With a tight, stockish converter it will bark the tires when it shifts 1-2 without it. Clutchflite? Brutal, just brutal either way.
[Re: 6PAX]
#3083654
10/05/22 08:14 PM
10/05/22 08:14 PM
Posts: 1,151 Loudoun County, VA
Brad_Haak
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3083791
10/06/22 12:19 PM
10/06/22 12:19 PM
Posts: 11,649 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Accumulator function is to cushion the 1-2 shift.
Race car, race car with tags, chirp the tires shift - leave the springs out and use a blocker rod.
Street car, cruiser, mild mods, don't want your teeth rattled - leave it in.
Some valve bodies don't even require the piston to be there.
[Re: 6PAX]
#3083798
10/06/22 12:27 PM
10/06/22 12:27 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The bottom line is:
the outer accumulator spring serves only to cushion the application of the front clutch and has no function on any upshift.
[Re: John_Kunkel]
#3083974
10/07/22 08:29 AM
10/07/22 08:29 AM
JohnRR
U.S.S.A.
The bottom line is:
the outer accumulator spring serves only to cushion the application of the front clutch and has no function on any upshift. With this in mind what was causing the harsh shift I had in my 2000 Ram ? I had a billet acc piston and blocker rod, and the shift was really harder than I liked, when to took out the blocker and put the spring back the hard shift was gone? I can't remember which shift it was , want to say it was 1-2 , I haven't driven that trans in a decade but it will be finding a new home in the Ram I bought earlier this year when I turn the Cummins up a little in this one.
[Re: 6PAX]
#3083975
10/07/22 08:32 AM
10/07/22 08:32 AM
JohnRR
U.S.S.A.
I guess I'll leave it in. Don't really want hard shifts nor care about chirping the tires but does leaving it in defeat the purpose of using this particular valve body? Would I be better off just leaving the factory valve body in the trans.? Engine is a 400/470 stroker. You are still getting the benefits of the valvebody so I would swap it. It's not a big deal, to me anyway , to drop[ the pan and valvebody so maybe run it without the spring and add the blocker and if it's too harsh take out the blocker and put in the spring ? If you have a pan with a draain plug using a clean catch pan you can recyle the drained fluid. And for god's sake don't put that ATF+4 shift in the trans.
[Re: 6PAX]
#3084062
10/07/22 01:31 PM
10/07/22 01:31 PM
John_Kunkel
Rio Linda, CA
I guess I'll leave it in. Don't really want hard shifts nor care about chirping the tires but does leaving it in defeat the purpose of using this particular valve body? Once again, the outer accumulator spring DOES NOT cushion any upshift...it's an old Mopar myth. Spring or no spring, as long as the accumulator piston is free to move it will cushion the 1-2 upshift.
[Re: John_Kunkel]
#3084132
10/07/22 08:02 PM
10/07/22 08:02 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I guess I'll leave it in. Don't really want hard shifts nor care about chirping the tires but does leaving it in defeat the purpose of using this particular valve body? Once again, the outer accumulator spring DOES NOT cushion any upshift...it's an old Mopar myth. Spring or no spring, as long as the accumulator piston is free to move it will cushion the 1-2 upshift. What is actually accomplished by pulling the springs and blocking it? I wouldn't do one without the other. Haven't done a stock rebuild in years. Only race stuff with a good VB. Piston with blocker in all of them.
[Re: John_Kunkel]
#3084142
10/07/22 08:40 PM
10/07/22 08:40 PM
Guitar Jones
I guess I'll leave it in. Don't really want hard shifts nor care about chirping the tires but does leaving it in defeat the purpose of using this particular valve body? Once again, the outer accumulator spring DOES NOT cushion any upshift...it's an old Mopar myth. Spring or no spring, as long as the accumulator piston is free to move it will cushion the 1-2 upshift. The accumulator does affect the 1/2 shift. Removing the outer spring without blocking it hammers the accumulator piston, I have seen them cracked from this, why would you remove it without blocking it? Some of the performance transmissions had an inner spring on the accumulator to hold it down from the factory. Moral to the story, if you remove the outer spring, block the piston.
[Re: CMcAllister]
#3084293
10/08/22 12:25 PM
10/08/22 12:25 PM
John_Kunkel
Rio Linda, CA
This effectively cancels the cushioning function of the accumulator...makes a firmer 1-2 upshift but risks damaging the rear clutch.
[Re: John_Kunkel]
#3084388
10/08/22 06:34 PM
10/08/22 06:34 PM
Guitar Jones
This effectively cancels the cushioning function of the accumulator...makes a firmer 1-2 upshift but risks damaging the rear clutch. How can it damage the rear clutch when it is already applied in all forward gears? The only thing happening on the 1/2 shift is the front band is applied unless you manually shifted from 1st to 2nd with an auto shift valve body or a rear band apply manual valve body. In which case then the rear band is releasing on the 1/2 shift. At no point is the rear clutch released and re applied, it is constantly applied 1/2/3. What damages the rear clutch is shifting from reverse to drive without coming to a stop. Effectively using the rear clutch as a vehicle brake.
[Re: John_Kunkel]
#3084421
10/08/22 08:19 PM
10/08/22 08:19 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
This effectively cancels the cushioning function of the accumulator...makes a firmer 1-2 upshift but risks damaging the rear clutch. That has been my understanding. Get the band applied more aggressively. Just wanted to make sure I wasn't missing something. Everything I've done in recent years has been race units, Accumulator is made non-functional. Years ago, we would do that on our hopped up street cars. With the manual Cheetah VBs, blocked accumulators and the ever present overlap, it could be obnoxious just cruising around..
[Re: Guitar Jones]
#3084574
10/09/22 03:05 PM
10/09/22 03:05 PM
John_Kunkel
Rio Linda, CA
This effectively cancels the cushioning function of the accumulator...makes a firmer 1-2 upshift but risks damaging the rear clutch. How can it damage the rear clutch when it is already applied in all forward gears? The only thing happening on the 1/2 shift is the front band is applied unless you manually shifted from 1st to 2nd with an auto shift valve body or a rear band apply manual valve body. In which case then the rear band is releasing on the 1/2 shift. At no point is the rear clutch released and re applied, it is constantly applied 1/2/3. What damages the rear clutch is shifting from reverse to drive without coming to a stop. Effectively using the rear clutch as a vehicle brake. The accumulator outer spring cushions the initial application of the rear clutch i.e. from N to D or 1. Without the spring, the rear clutch piston applies harder and can overwhelm the Belleville spring causing it to break or pop the piston out of its bore.
[Re: John_Kunkel]
#3084901
10/10/22 04:44 PM
10/10/22 04:44 PM
Guitar Jones
I can see where if the spring was just removed and the servo wasn't blocked that, that may be a problem, but since there is line pressure above and below the accumulator servo they should cancel each other out with the servo blocked. I can also see where increased line pressure could be a problem, or throwing it in drive while on fast idle or a neutral drop would cause that.
[Re: J_BODY]
#3085063
10/11/22 10:33 AM
10/11/22 10:33 AM
JohnRR
U.S.S.A.
Ran +4 in my built 47RE. I even run it it my 904 in the race car I'm other way , I don't run + anything in my built 47RE .
