video of test drive around block #3083871
10/06/22 04:31 PM
10/06/22 04:31 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I need to work on the cruise afr to start in my 3 circuit holley 80532-1 carbs[1250cfm]x2 I am testing at 14# because idk how low [8#] would effect the afr with flow through the carbs.Currently stepping into the gas slow gets me 13 low rpm to 14.4 at lets say 4500 rpm so I think I need to close some of the emulsion jets li 2 of the 5 [.025 size] I have mufflers,street tires,Insureance but testing is still risky on the street as you may understand .I am working on an electrical issue/reliabillity so I can test at the track t&t.I get on the gas at 1:24 sec into the video.
Re: video of test drive around block [Re: Clanton] #3083886
10/06/22 05:56 PM
10/06/22 05:56 PM
birdtracker Offline
birdtracker  Offline
congrats, thanks for posting. Birdtracker
Re: video of test drive around block [Re: birdtracker] #3083894
10/06/22 07:00 PM
10/06/22 07:00 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Cool car
Re: video of test drive around block [Re: FastmOp] #3083895
10/06/22 07:03 PM
10/06/22 07:03 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Originally Posted by FastmOp
Cool car
Thank you!
Re: video of test drive around block [Re: Clanton] #3083896
10/06/22 07:04 PM
10/06/22 07:04 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Good stuff Mike. Bad to the bone Man.
Re: video of test drive around block [Re: Clanton] #3083911
10/06/22 08:27 PM
10/06/22 08:27 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I think I can take out some from the intermediat air bleed,likely 61 to a 40 lets say and not get into boost at around 1/4 throttle as you could see.
Re: video of test drive around block [Re: Clanton] #3083914
10/06/22 08:39 PM
10/06/22 08:39 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Wish I had a mad max type in my neighborhood, id buy a new lawn chair. up
STOP POTATO HATE!
Re: video of test drive around block [Re: Mr PotatoHead] #3083920
10/06/22 09:15 PM
10/06/22 09:15 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My car is about 100 decibels at 50' so stay back from the curb. LOL
Re: video of test drive around block [Re: Clanton] #3084008
10/07/22 10:21 AM
10/07/22 10:21 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Nice.....I am building somthing very similar, and I hope mine runs as well as yours. You don't even seem to have the blower lope most do...Very smooth driving....
Mine is also 446 cubes, but with an OEM block and I will be ordering the 8-71 soon from TBS. It was built by a friend of mine that ran it on E85 with an 8-71....How did you come to using two 1250 Dominators? I have a pair of 750's I am going to try. And no boost refrencing?
Re: video of test drive around block [Re: Dragula] #3084037
10/07/22 11:44 AM
10/07/22 11:44 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Boost reference is for blow through applications only. In a draw through there is no pressure on the float bowl. In a blow through the float bowls also see boost, you have to raise the fuel pressure at the 1:1 ratio so the carb works as normal, otherwise the fuel gets forced back into the lines.
68 Barracuda Formula S 340
Re: video of test drive around block [Re: Dragula] #3084041
10/07/22 12:05 PM
10/07/22 12:05 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you for liking my car! I started with 850's 20yrs ago and my top goal of 20# after I got a Koleno block the cfm requirements went up and blowers don't like restriction so I got as big as I felt I could deal with and on the dyno I lost 100*F from bigger carbs. Setting up the carbs to start and have the least lope takes some time testing what pump shot it takes and how rough it runs getting it warmed up and turns out to be 12.5 afr at idle cold and it warms to about 13.5 and when warmed up the lope starts at 13/1 afr.
Re: video of test drive around block [Re: Clanton] #3084046
10/07/22 12:22 PM
10/07/22 12:22 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
here is a good video on a roots going from pump gas to using NOS with boost in steps including E85.
Re: video of test drive around block [Re: Clanton] #3084047
10/07/22 12:25 PM
10/07/22 12:25 PM
I take it you run pump gas? What is target AFR for WOT? And what is your max boost?
Re: video of test drive around block [Re: Dragula] #3084052
10/07/22 12:52 PM
10/07/22 12:52 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
No I have run sunoco/VP 110 from the beginning and afr12.or a little lower 11.5 full timing at 34* 9/1 cr 14# for the last 17yrs. with factory iron heads to start and then Edel Victor std pot now,.631 lift 260 dur at .050 112 lsa
Re: video of test drive around block [Re: Clanton] #3084095
10/07/22 03:44 PM
10/07/22 03:44 PM
Cool....I might bug you later...so much to learn on these boosted setups...Shooting to start at #10 on mine and land around #15 later....Guy I bought it off of, said it has seen #22.....But it was too hairy to drive....
Re: video of test drive around block [Re: Mr PotatoHead] #3085109
10/11/22 12:41 PM
10/11/22 12:41 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
LOL
Re: video of test drive around block [Re: HardcoreB] #3085110
10/11/22 12:41 PM
10/11/22 12:41 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice to see the car up and running again!
Re: video of test drive around block [Re: HardcoreB] #3085368
10/12/22 10:52 AM
10/12/22 10:52 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Where's your neighbor hood, Clanton?
I live east of Cleveland and would like a roadside seat next time you take a test!!
Joe
Re: video of test drive around block [Re: jlatessa] #3085370
10/12/22 10:56 AM
10/12/22 10:56 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Joe
Gas, Grass or A$$ and he might let u ride lmfao
Re: video of test drive around block [Re: FastmOp] #3085397
10/12/22 11:59 AM
10/12/22 11:59 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Joe
Just gas but last time I got some was 14$ a gal. this yr and last yr was only 8.50$ for VP110
