How "big" is a TF270 intake port?
#3083547
10/05/22 12:44 PM
10/05/22 12:44 PM
Posts: 1,118 Loudoun County, VA
Brad_Haak
Loudoun County, VA
It may have an Max Wedge entry, but without offset intake rockers it's gotta be fairly limited in MCSA, especially at the pushrod pinch. Anybody taken or seen any MCSA / Average CSA measurements for the TF270?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: How "big" is a TF270 intake port?
[Re: Al_Alguire]
#3083556
10/05/22 01:09 PM
10/05/22 01:09 PM
Brad_Haak
Loudoun County, VA
^^^^ "Hello... Newman"
[Re: Hot 340]
#3083692
10/05/22 10:56 PM
10/05/22 10:56 PM
Posts: 30,995 Oregon
AndyF
I saw a pair on display at summit in Ohio. They were pee wee stuff compared to the other brands offerings. They looked like 200 cc heads🤣 Yes, Mopar BB heads are very small compared to something like a BB Chevy head. That is why it is easier to make power with a big BBC than a big Mopar BB. The TF270 heads provide the average backyard builder with a good 700 head. A pro engine builder can get 800 hp out a set of TF270 heads but it gets hard to make more than that NA. If you want to run a BBC then you can buy a 1000 hp pump gas street engine. The BBC has become a much better engine for making power over the last 30 years because GM has continued to upgrade the design. Mopar never upgraded the big block design so we're still stuck with two piece rear main seal and other outdated features. I have a customer with a Mark VI big block and it has substantial upgrades when compared to the muscle car era design.
[Re: AndyF]
#3083726
10/06/22 08:00 AM
10/06/22 08:00 AM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I saw a pair on display at summit in Ohio. They were pee wee stuff compared to the other brands offerings. They looked like 200 cc heads🤣 Yes, Mopar BB heads are very small compared to something like a BB Chevy head. That is why it is easier to make power with a big BBC than a big Mopar BB. The TF270 heads provide the average backyard builder with a good 700 head. A pro engine builder can get 800 hp out a set of TF270 heads but it gets hard to make more than that NA. If you want to run a BBC then you can buy a 1000 hp pump gas street engine. The BBC has become a much better engine for making power over the last 30 years because GM has continued to upgrade the design. Mopar never upgraded the big block design so we're still stuck with two piece rear main seal and other outdated features. I have a customer with a Mark VI big block and it has substantial upgrades when compared to the muscle car era design. Has ANYBODY updated the combustion chamber from 1958 yet? That seems like it should be a zero $$$ cost upgrade because you have to make a pattern for the mold anyway. Make it a shape that works better. Lots to copy from. Kevin
[Re: AndyF]
#3083745
10/06/22 09:27 AM
10/06/22 09:27 AM
Posts: 5,161 CT
GTX MATT
CT
I saw a pair on display at summit in Ohio. They were pee wee stuff compared to the other brands offerings. They looked like 200 cc heads🤣 Yes, Mopar BB heads are very small compared to something like a BB Chevy head. That is why it is easier to make power with a big BBC than a big Mopar BB. The TF270 heads provide the average backyard builder with a good 700 head. A pro engine builder can get 800 hp out a set of TF270 heads but it gets hard to make more than that NA. If you want to run a BBC then you can buy a 1000 hp pump gas street engine. The BBC has become a much better engine for making power over the last 30 years because GM has continued to upgrade the design. Mopar never upgraded the big block design so we're still stuck with two piece rear main seal and other outdated features. I have a customer with a Mark VI big block and it has substantial upgrades when compared to the muscle car era design. And Mopar guys will put a standard port window on a 500+ cubic inch engine for fear of losing torque. A std port B/RB is comparable in size to a “peanut port” BBC head.
[Re: birdtracker]
#3083753
10/06/22 09:52 AM
10/06/22 09:52 AM
Brad_Haak
Loudoun County, VA
... Guess I am on the naughty list as Santa didn't bring mine!!!! Birdtracker Santa left me a note a few years ago: "Dear Brad,
You've been an a-hole this year; no Trick Flows for you!
Instead, I'm leaving a set of bare Victor castings that need everything done to be ready to go. Have fun!
Santa (Yeah, I can be an a-hole, too) Claus"
[Re: HardcoreB]
#3083755
10/06/22 09:58 AM
10/06/22 09:58 AM
Brad_Haak
Loudoun County, VA
Should be REALLY simple...whomever has a 270 head just measure the pushrod pinch area and report back please. For reference, the SR's I did about 1.21 is near max in width without repair work. width x height The pics I was checking out -- as Andy mentioned -- don't show a lot of pinch. Looks like TF did a good job of maximizing the available real estate for a standard-offset intake rocker.
[Re: Al_Alguire]
#3083796
10/06/22 12:24 PM
10/06/22 12:24 PM
Brad_Haak
Loudoun County, VA
Ehhhh if omeone does try to make BETTER parts, like cylinder heads most the Mopar purists will just throw it under the bus and complain that its not a BBM looks like brand X stuff to me....Ask me how I know For people trying to build serious & competitive Mopar-based engines, it's got to be waaaay frustrating at the lack of options or availability.
[Re: Brad_Haak]
#3083808
10/06/22 12:54 PM
10/06/22 12:54 PM
AndyF
Ehhhh if omeone does try to make BETTER parts, like cylinder heads most the Mopar purists will just throw it under the bus and complain that its not a BBM looks like brand X stuff to me....Ask me how I know For people trying to build serious & competitive Mopar-based engines, it's got to be waaaay frustrating at the lack of options or availability. A 572 built with an Indy block and 572-13 heads is a pretty stout combo for bracket racing. It costs a lot more than a 1000 hp 632 inch BBC crate motor, but it will make good power and it looks like a Mopar It is that is now easier than ever to build a 700 or 800 hp BB Mopar that uses "classic" Mopar parts and looks like a Mopar. If a guy is happy with a 9 or even 8 second door slammer than everything is cool. I don't worry about this too much. Buick, Olds and Pontiac guys have had this issue for years. Ford guys have some nice options and Chevy BB guys have tons of options. Mopar guys are better off than the BOP guys but don't have the factory support of either the Ford or Chevy guys. Just the way it is due to decisions made by Mopar Performance years ago. They could've solved the block problem 20 years ago but they didn't. They could've solved the head problem 20 years ago but they didn't. Nothing we can do about their failure to make good decisions years ago. Trick Flow did a big favor for the 600 to 800 hp crowd, and Indy still has good options for the 700 to 900 hp crowd so 90% of the bracket racers are covered. It is just the die hard Mopar guys who want to make more than 1000 hp who have it tough.
[Re: AndyF]
#3083815
10/06/22 01:01 PM
10/06/22 01:01 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Ehhhh if omeone does try to make BETTER parts, like cylinder heads most the Mopar purists will just throw it under the bus and complain that its not a BBM looks like brand X stuff to me....Ask me how I know For people trying to build serious & competitive Mopar-based engines, it's got to be waaaay frustrating at the lack of options or availability. A 572 built with an Indy block and 572-13 heads is a pretty stout combo for bracket racing. It costs a lot more than a 1000 hp 632 inch BBC crate motor, but it will make good power and it looks like a Mopar It is that is now easier than ever to build a 700 or 800 hp BB Mopar that uses "classic" Mopar parts and looks like a Mopar. If a guy is happy with a 9 or even 8 second door slammer than everything is cool. I don't worry about this too much. Buick, Olds and Pontiac guys have had this issue for years. Ford guys have some nice options and Chevy BB guys have tons of options. Mopar guys are better off than the BOP guys but don't have the factory support of either the Ford or Chevy guys. Just the way it is due to decisions made by Mopar Performance years ago. They could've solved the block problem 20 years ago but they didn't. They could've solved the head problem 20 years ago but they didn't. Nothing we can do about their failure to make good decisions years ago. Trick Flow did a big favor for the 600 to 800 hp crowd, and Indy still has good options for the 700 to 900 hp crowd so 90% of the bracket racers are covered. It is just the die hard Mopar guys who want to make more than 1000 hp who have it tough. I would think this is where people get into weight loss of the vehicle and class being raced in for what you can do with a wedge engine mopar based.
[Re: GTX MATT]
#3083862
10/06/22 03:54 PM
10/06/22 03:54 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I saw a pair on display at summit in Ohio. They were pee wee stuff compared to the other brands offerings. They looked like 200 cc heads🤣 Yes, Mopar BB heads are very small compared to something like a BB Chevy head. That is why it is easier to make power with a big BBC than a big Mopar BB. The TF270 heads provide the average backyard builder with a good 700 head. A pro engine builder can get 800 hp out a set of TF270 heads but it gets hard to make more than that NA. If you want to run a BBC then you can buy a 1000 hp pump gas street engine. The BBC has become a much better engine for making power over the last 30 years because GM has continued to upgrade the design. Mopar never upgraded the big block design so we're still stuck with two piece rear main seal and other outdated features. I have a customer with a Mark VI big block and it has substantial upgrades when compared to the muscle car era design. And Mopar guys will put a standard port window on a 500+ cubic inch engine for fear of losing torque. A std port B/RB is comparable in size to a “peanut port” BBC head. A 6.4 hemi head is about as big as any common BB heads and does not lack any TQ when slapped on a 5.7 hemi, even max ported to around 400CFM with a huge cross section they make plenty of TQ on a 6.4. I have come to the conclusion a small port is just a governor to keep it from making too much power at higher RPM if you can even get it to turn very many RPM. A 500+ BB will still make plenty of TQ with some huge Gen II hemi heads. Cam timing events are for adjusting TQ, cylinder heads are for building HP. A BBM is no different than any other engine.
[Re: Twostick]
#3083863
10/06/22 03:56 PM
10/06/22 03:56 PM
HotRodDave
Kalispell Mt.
I saw a pair on display at summit in Ohio. They were pee wee stuff compared to the other brands offerings. They looked like 200 cc heads🤣 Yes, Mopar BB heads are very small compared to something like a BB Chevy head. That is why it is easier to make power with a big BBC than a big Mopar BB. The TF270 heads provide the average backyard builder with a good 700 head. A pro engine builder can get 800 hp out a set of TF270 heads but it gets hard to make more than that NA. If you want to run a BBC then you can buy a 1000 hp pump gas street engine. The BBC has become a much better engine for making power over the last 30 years because GM has continued to upgrade the design. Mopar never upgraded the big block design so we're still stuck with two piece rear main seal and other outdated features. I have a customer with a Mark VI big block and it has substantial upgrades when compared to the muscle car era design. Has ANYBODY updated the combustion chamber from 1958 yet? That seems like it should be a zero $$$ cost upgrade because you have to make a pattern for the mold anyway. Make it a shape that works better. Lots to copy from. Kevin In order to get a significantly better chamber in a BBM head they need to move the valves because they are in a weird spot, this requires different pistons and most guys just don't want to be bothered with all those changes.
[Re: HotRodDave]
#3083867
10/06/22 04:13 PM
10/06/22 04:13 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
I have done both and the costs are not that much greater for a BBM than a BBC at 1000 HP. Cranks, Rods, Pitons, Rings, Lifters, Cams, Oiling parts, a;l those are are the SAME cost pretty much. I have both so I know. Feel free to price and aluminum BB chevy block and get back to me. Heads of similar performance potential are pretty much the same cost. Porting is porting don't matter what head it is the price is the same. The difference is options for the BBC guys, the initial cost of an ironblock is another, although most those lower dollar Chevy blocks need work to make them useful at that power leve,like cam cores, lifter sizing so that brings the cost more inline. Also the secondary market for BBC stuff is much larger than the BBM one. Building new it is a few grand either way, so if a few grand is gonna break your budget on a 1000hp combo then maybe you need to rethink your hobby and finances.
I have seen more than my fair share of crate engines from many of the larger name Chevy shops. Most do not perform anywhere near their posted HP numbers. The exception to that rule is Reher and Morrison, and again feel free to look at their prices and get back to me. I have seen the inside of them as well and many are downright SCARY when you get in there, the lack of attention to detail and quality workmanship, again Reher is a glaring exception again. There are the nicest pieces you will find.
Bottom line IMO. Many Mopar guys shy away from trying to make HP. Because they keep getting told it cant be done, or it cost to much, or its way cheaper to build a BBC. Some are scared of the RPM it might take to get there. Others don't want to or refuse to come around to more modern thinking on making HP. Or most the most likely reason is they are happy making 7-800 and running where they are. Nothing wrong with it.BUt its what keeps the Mopar stuff limited to what we have. I am on my third Predator build right now. Was it cheap HELL no. Could I build a BBC for less, yeah maybe 2500-3000 less. In the end it will make a bit over 1100hp and be a reliable bracket/.90 engine for me. Have a 582 aluminum BBC going together right next to it as well. And the costs difference is nominal and the Predator will make more power.
[Re: Al_Alguire]
#3083880
10/06/22 04:48 PM
10/06/22 04:48 PM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
thanks Al for your insight , again . Always the case of " I want vs I need " . I see it at work , everyone wants a 700+ HP motor for tootling around and going to the shops . My opinion is unless you are racing why bother ? As long as you can do a burn out on the street just lie about the HP . Andy thanks also withyour comments re Tflow and the boost to a lot of mid level bracket racers . I'm one of them . Now all I need is to get rid of 100lbs or so from the Satellite . Don't forget some racers dont want the extra SFI parts turnover or extra safety gear that a higher HP / ET car brings . So that sorta easy 700 or so HP number is fine , especially in a dual purpose car . And yes I have the TF 270s on my 505 and laugh with fellow Ford/Chev racers about how small the port sizes are , even @ Max Wedge size . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3084006
10/07/22 10:18 AM
10/07/22 10:18 AM
Brad_Haak
Loudoun County, VA
^^^ Big ports iz scary...
[Re: Al_Alguire]
#3084650
10/09/22 08:30 PM
10/09/22 08:30 PM
Posts: 6,136 Melbourne , Australia
LA360
Bottom line IMO. Many Mopar guys shy away from trying to make HP. Because they keep getting told it cant be done, or it cost to much, or its way cheaper to build a BBC. Some are scared of the RPM it might take to get there. Others don't want to or refuse to come around to more modern thinking on making HP. Or most the most likely reason is they are happy making 7-800 and running where they are. Nothing wrong with it.BUt its what keeps the Mopar stuff limited to what we have. I am on my third Predator build right now. Was it cheap HELL no. Could I build a BBC for less, yeah maybe 2500-3000 less. In the end it will make a bit over 1100hp and be a reliable bracket/.90 engine for me. Have a 582 aluminum BBC going together right next to it as well. And the costs difference is nominal and the Predator will make more power. I've seen a few crate engines make their way down here, only to ruin the crankshaft or eat itself in some way after about 2000 klms. As Al pointed out, no attention to detail. The Trickflow stuff is nicely made, but most BBM heads are just plain tiny port wise.
Alan Jones
