Re: AFB Lobotomy [Re: Cab_Burge] #3082311
10/01/22 05:14 PM
10/01/22 05:14 PM
West Palm Beach, Florida
Craig J Offline OP
Craig J  Offline OP
Seems to work ok. I think the choke function is not as effective but I probably won't be driving much in weather below 32F so probably not an issue.
Started with 0.55, then 0.70, now .063...
Re: AFB Lobotomy [Re: Cab_Burge] #3082314
10/01/22 05:36 PM
10/01/22 05:36 PM
Craig J Offline OP
Craig J  Offline OP
Originally Posted by Cab_Burge
Why did you do this? confused
Mostly to see if it would work. But honestly this is not even close to my worst/best idea...
BDS 14-7100065.pngBDS 14-7100041.jpgBDS 14-7100007.jpg2009 WOrld Of Speed 00018.jpg
Re: AFB Lobotomy [Re: Craig J] #3082393
10/02/22 12:02 AM
10/02/22 12:02 AM
Cab_Burge Online work
Cab_Burge  Online Work
BDS use to only make junk blowers, I wonder about them now work
Littlefields were a lot better 20 years ago up
I wanted to build a Bonniville car years back but SCTA and BNI eliminated the class I wanted to run it in before I could finish the car whiney shruggy
Re: AFB Lobotomy [Re: Cab_Burge] #3082760
10/03/22 12:28 PM
10/03/22 12:28 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
My question is why ?
All that work and time on the 1407/1411 for what gains honestly - Subject has been beat to death on every Mopar site on the web
And the reasons have been stated over and over and over
So many better options
The Edelbrock AVS 2 is one hundred times better in every aspect right out of the box
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: AFB Lobotomy [Re: dvw] #3082773
10/03/22 12:31 PM
10/03/22 12:31 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Originally Posted by dvw
I'd be interested to see what the air bleed changes are worth. I raced my car 8 years with a pair if 1407s. There was definitely an issue leaving off the foot brake even at 3000 rpm. Getting ready to run these carbs on my sons racecar. I've opened up the secondary well feeds. Tried heavy/light air doors. Various squirters. Raised the float levels. Run the idle fat. Never messed with the idle restrictions or bleeds. Never messed with the transfer slot location. At times we ran quick. But not near as consistent as the Holley's.
Doug
First time I heard you say anything negative about those 1407s
Siberian Huskies
Re: AFB Lobotomy [Re: bee1971] #3082942
10/03/22 06:29 PM
10/03/22 06:29 PM
Craig J Offline OP
Craig J  Offline OP
This time I am using a 1406 it does not have the off idle lean spot. In the past the I made the 1407 work "ok" by making a really crude modification to the transfer slot using a jigsaw blade... but it was never really right.
Re: AFB Lobotomy [Re: Craig J] #3083122
10/04/22 07:49 AM
10/04/22 07:49 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've never experienced the "off idle" lean spot with a 1407, and i've really leaned them up before; shruggy. something i don't and never do is the big squirter thing. i use the correct accelerator pump and have the pump rod in the top hole. my experience has always been very smooth operation, even with bad calibration.
