Re: Trim Ring Question
[Re: VitaminCRunner]
#3080009
09/23/22 03:19 PM
09/23/22 03:19 PM
Posts: 3,524 Lansing, MI
70gtx440dana
Lansing, MI
Mopar made 3" deep trim rings for the 70-72 style 15x7 rims.They made polished and brushed versions....keep an eye open for them. However, be prepared for sticker shock. Damaged cores bring $150+ each. Restored set of 4 = $2000 or More. NOS set of 4 $4000+
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: TJP]
#3080267
09/24/22 01:12 PM
09/24/22 01:12 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
Take the polished ones and brush them to your desired texture. easily done with the rear end on jackstands, a bare wheel mounted to the axle with trim ring installed. Tthe motor idling in gear and a ultra fine scothbrite pad. Too dull, polish a bit using same method. this works, i'd spray a little wd40 on the ring first, for lube.
