Re: 5.7 into a 91 dakota. Motor mounts?????
[Re: dart67]
#3080302
09/24/22 04:38 PM
09/24/22 04:38 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Holley makes swap motor mounts. But they are soposed to move your engine forward 3 inches to clear the SRV valve on the back of the 6.4 intake.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: dart67]
#3081192
09/27/22 04:59 PM
09/27/22 04:59 PM
Posts: 1,397 Toronto Ontario, Can
Glen440
If you are going farther back then you will have better oil pan clearance. I went the cheapest route by getting a factory truck pan and notching the crossmember. The exhaust ports are close to the upper control arm on the passenger side. The lower control arm mount also makes it tight for the header.
87 dakota 6.1 hemi
[Re: Glen440]
#3081291
09/27/22 10:01 PM
09/27/22 10:01 PM
Posts: 898 Ky.
dart67
Ky.
I was thinking about keeping the factory exhaust manifolds instead of headers. This is just a driver. Hopefully the wife will drive it. Doing it for her.
At first glance, it looks like the factory exhaust will lay closer to the head than a header would?
The engine came out of a truck, with sump at rear.
What did you use to get the steel plate away from the block? Do I see nuts in the pic?
Did you move the oil filter?
[Re: dart67]
#3081837
09/29/22 09:31 PM
09/29/22 09:31 PM
Glen440
I tried stock 5.7 manifolds from the cars. Not even close. It's 3 inches from head to the control arm. Truck manifold may be better. I used nuts that were bigger than the bolts. I started with washers to get them even. Just happened to be the right length stacking nuts. The oil filter is directly on the block pointing down. I'm using the car front. AC compressor is down low on driver side.
87 dakota 6.1 hemi
[Re: dart67]
#3083641
10/05/22 07:07 PM
10/05/22 07:07 PM
Glen440
I took a measurement of the one spot I can reach. Spacer is just under an inch. Plate is 1/4 inch. So it's a tiny bit under 1 1/4" total. I'm guessing bolts would be around 1 3/4". They are metric from memory, maybe 10mm. No aluminum bolts. Only standard bolts I came across are transmission bellhouse. Was a little tricky bolting the mount to the plate.
The way I came up with the height was I matched the v6. I left the 904 in and kept the Trans at the same height. I think some people raise the engine to get more clearance.
87 dakota 6.1 hemi
[Re: dart67]
#3087034
10/18/22 02:02 AM
10/18/22 02:02 AM
mopar65
Thanks for the info and build pics. I have a 5.7 stroker engine i am going to build and put in my 91 dakota. I was told the holley swap motor mounts were made to move the engine forward to clear the SRV valve on the 6.4 intake. Also the cooler lines on the back of the hell cat engine. On the oil pan have you looked into one for a 5.7 hemi jeep? I don't know if it would fit but it looks like they are a rear sump pan.
support our troops
