Super charger racers, how much compression ratio? #3077826
09/16/22 01:42 PM
09/16/22 01:42 PM
Cab_Burge Offline OP
I'm in the middle of starting to build a crank driven centrifugal supercharge motor for some local No Prep racing next year, hopefully luck
The motor will be a BB wedge Koleno block with B1-MC heads, 4.5 bore with 4.375 stroke, the Vorteck V30-123A super charger is capable of 40+ lbs. boost and 4000 CFM.
I want to try racing it on E85 and i have no idea on what mechanical compression ratio to make it have to start with help
Any and all suggestions will be greatly appreciated up bow
Re: Super charger racers, how much compression ratio? [Re: Cab_Burge] #3077850
09/16/22 03:15 PM
09/16/22 03:15 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am just getting into this game, and everyone seems to come back with 8-9:1 even with E85 fuel....The motor I have dibs on is 8:1 and made nearly 1200hp at 22psi....at around 450ci
Re: Super charger racers, how much compression ratio? [Re: Dragula] #3077976
09/16/22 10:53 PM
09/16/22 10:53 PM
I've been told from up to 14.0 to 1 and down to 8.5 to 1 mechanical compression ratio confused
I know the NHRA blown alcohol racers use 11.5 to 1 and up to 13.5 to 1 compression ratio on methanol with a bunch of boost, 45+ lbs. boost and over 11,000 RPM shock
I've also been told that they are now making north of 4500 HP, I'm shooting for between 2200 and 2700 HP on E85 at or below 8500 RPM: luck:
Re: Super charger racers, how much compression ratio? [Re: Cab_Burge] #3079161
09/20/22 09:27 PM
09/20/22 09:27 PM
NY
B1duster Offline
B1duster  Offline
NY
I’d say it’s going to take pretty $eriou$ effort.
Please keep us posted
Re: Super charger racers, how much compression ratio? [Re: B1duster] #3079234
09/21/22 08:41 AM
09/21/22 08:41 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
What will the boost pressure be at launch?
Re: Super charger racers, how much compression ratio? [Re: Uberpube] #3079338
09/21/22 03:46 PM
09/21/22 03:46 PM
i have no idea, yet work
This will be all new to me, boost, E85 and no prep shruggy
I'll have to try different things as far as starting line RPM, boost on the line and shift RPM, I have a lot to learn: wrench:
Hopefully it will be fun and not hurt a bunch of parts learning, hence me asking about the compression ratio now luck
Re: Super charger racers, how much compression ratio? [Re: Cab_Burge] #3079720
09/22/22 06:43 PM
09/22/22 06:43 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
If you have everything picked out, you can make a reasonable estimate of where the emap will be. A motor for boost
Will like flow as much as an NA motor, but the compression requirements are different no matter what youtubers like to say.
Will you be running an intercooler or relying strictly on the latent heat of vaporization of the fuel?
Re: Super charger racers, how much compression ratio? [Re: Uberpube] #3079794
09/22/22 10:40 PM
09/22/22 10:40 PM
I've heard and been told no and yes on intercooling so far.
I know some guys who use to run an old style 392 hemi in Top Alcohol dragster, they were using Brad Andersen parts and his help on tuning. They had 12.0 to 1 compression ratio and Brad wanted them to increase it up to 13.+ to 1 ratio on straight methanol with the blowers available back then shruggy
I may try it first without an intercooler and monitor the manifold inlet temps and decide from them on adding intercoolers or not work
I'm planning on going with really safe set ups to start with on all the tuning and see what it does and look at the plugs and time slips and go from there luck
I got a lot on my plate to get done before then so I'm in no rush, I'm trying to get everything right before starting hence my question on the compression ratios on E85 now luck
Thanks to all for your help on this bow up grin
Re: Super charger racers, how much compression ratio? [Re: Cab_Burge] #3079814
09/23/22 01:13 AM
09/23/22 01:13 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I would look at it a different way. As in, what is your goal?
ET/MPH at what weight or power at what rpm?
I think it's been said but basically as you raise compression, if everything else is optimized for it, you will make more power as you narrow your tuning window.
Said in another way, less room for error.
If I was building what I think you're trying to build I would do twin turbo and methanol.
Re: Super charger racers, how much compression ratio? [Re: Cab_Burge] #3079843
09/23/22 08:03 AM
09/23/22 08:03 AM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
How important is it to you to run E85? I think E85 is great for a boosted street driven car with restrictions on boost but this sounds like 100% race car. Just go straight to Methanol. Race car, race fuel. Put it at 12:1 compression and call someone like Bullet for the cam. I have a much smaller blower on a 405 cubic inch engine and it makes 11 psi on the brake and 38 psi by the 60 foot clocks. Making power won't be the problem for you. Managing it will.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: Super charger racers, how much compression ratio? [Re: Runnoft] #3079978
09/23/22 01:54 PM
09/23/22 01:54 PM
[quote=. Making power won't be the problem for you. Managing it will. [/quote] iagree
I'm hoping to make around 2000 HP to start with by reducing the supercharger drive RPM and work on hooking it and learning how to tune it and then thank about turning it up luck
Re: Super charger racers, how much compression ratio? [Re: Cab_Burge] #3081856
09/29/22 10:53 PM
09/29/22 10:53 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
I was trying to find the compressor map for the supercharger you picked, I couldn't find one, do you have one?
Re: Super charger racers, how much compression ratio? [Re: Uberpube] #3081859
09/29/22 11:01 PM
09/29/22 11:01 PM
I don't have a clue what a super charger map is, sorry blush
In fact, I don't have a clue about what boost it will make at which crankshaft RPMs confused
I have a lot to learn, huh blush
Hopefully it won't kill me first luck
Re: Super charger racers, how much compression ratio? [Re: Cab_Burge] #3081864
09/29/22 11:15 PM
09/29/22 11:15 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
If you can get one, I will do some of the math work for you.
Re: Super charger racers, how much compression ratio? [Re: Uberpube] #3081890
09/30/22 07:55 AM
09/30/22 07:55 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Re: Super charger racers, how much compression ratio? [Re: racerx] #3081996
09/30/22 01:10 PM
09/30/22 01:10 PM
Yes Sir, that is the one I'm getting, hopefully soon luck
