Re: Dash reverse light on 70 auto roadrunner
[Re: 70mopes]
#3078936
09/20/22 04:25 AM
09/20/22 04:25 AM
Posts: 4,808 Castlegar, BC, Canada
That AMC Guy
Are you sure it's a reverse light and not a "Fasten Belts" light?
An automatic should never have received a reverse light.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: That AMC Guy]
#3079108
09/20/22 06:45 PM
09/20/22 06:45 PM
Posts: 1,757 Phila
PhillyRag
Phila
An automatic should never have received a reverse light. I once hooked up both to an e-body with 727. While not 100% correct, sure looked spiffy when lit.
[Re: 70mopes]
#3079199
09/21/22 01:31 AM
09/21/22 01:31 AM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
Any evidence of it being wired in to anything? Is the lamp harness that goes to bulkhead in place? Doesn't seem right....maybe a factory mistake or replaced in the 52 years it's been around.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70mopes]
#3079304
09/21/22 01:24 PM
09/21/22 01:24 PM
70gtx440dana
Lansing, MI
The car sat for probably the last 30 years. 20 at the guy I bought it from who never touched it and probably ten or more under a tree mostly covered by branches. It was last tabbed in 1980. While it lived a rough life, most of the car was original and complete right down to the original radio. Not cut up or modified in any way. You can see the slip in socket/bulb in the background of the one shot which is common to this type of light assy. Dash is coming out today. If you find it was wired in it is most likely a factory error. Odd mistake....but I guess it could have happened. What style seat belts are in the car? Flip up latch/cover or push button style? Push button style belts would have had seat belt warning dash lamp. Possibly installed the wrong lamp as they are basically the same.
