727 Trans Pan Stripped Bolt Hole Repair?
#3077929
09/16/22 08:29 PM
09/16/22 08:29 PM
Posts: 364 US
f2502011
US
Have a stripped bolt hole in an original numbers matching aluminum 727 TQFlite case. Has been helicoiled and re-helicoiled but won’t hold and leaks. Won’t torque to spec and when installed with bolt, the helicoil spins and rides back down the bolt and is able to be pulled out the hole with needle nose pliers. What are my options to fix? Replacing the trans with a non #s matching case isn’t an option.
1970 EK2 T/A 727
Re: 727 Trans Pan Stripped Bolt Hole Repair?
[Re: A727Tflite]
#3077952
09/16/22 09:26 PM
09/16/22 09:26 PM
Posts: 6,322 nowhere
Sniper
nowhere
Years ago, when I was in the Navy, I was stationed at an antenna overhaul shop for a while. When we ran into this kind of situation we would fill the hole with Decon Aluminum putty, re drill and re-helicoil it. If the helicoil is coming out it was improperly done.
[Re: Sniper]
#3077954
09/16/22 09:37 PM
09/16/22 09:37 PM
Posts: 21,545 N.E. OHIO, USA
A12
N.E. OHIO, USA
Years ago, when I was in the Navy, I was stationed at an antenna overhaul shop for a while. When we ran into this kind of situation we would fill the hole with Decon Aluminum putty, re drill and re-helicoil it. If the helicoil is coming out it was improperly done. Ah Sniper I think you mean Devcon aluminum epoxy (great stuff BTW) not the mouse and rat poison Decon (Yeah it happens when we get elderly DAMHIK ) Mike
[Re: A727Tflite]
#3077957
09/16/22 09:50 PM
09/16/22 09:50 PM
Posts: 15,503 Omaha Ne
TJP
Omaha Ne
Do you know if they use the same OD and pitch as Heli coil? This is very strange the heil coil is so loose. Almost make me wonder if someone used the wrong tap ( 8mm x 1.5? ) I have never encountered this in over 55 years of turning wrenches. Even if the time-sert goes in I would first THORUGLY clean the case threads, and install using an additional locking compound or possibly even JB weld. If one coats the installation tool with vaseline it will prevent the JB from plugging the female threads when removing the tool. Leave if sit the full 24 hours for curing. If the bolt will not go in easily, slowly run a SHARP tap in doing the 1/2 turn in, 1 turn out. If it's a blind hole you may need to follow up with a bottoming tap. Another possible option would be to press fit a plug in depending on the location and how much material you have to play with.
[Re: A12]
#3077958
09/16/22 09:52 PM
09/16/22 09:52 PM
TJP
Omaha Ne
Years ago, when I was in the Navy, I was stationed at an antenna overhaul shop for a while. When we ran into this kind of situation we would fill the hole with Decon Aluminum putty, re drill and re-helicoil it. If the helicoil is coming out it was improperly done. Ah Sniper I think you mean Devcon aluminum epoxy (great stuff BTW) not the mice and rat poison Decon (Yeah it happens when we get elderly DAMHIK ) Mike GOOD ONE LMAO
[Re: TJP]
#3077971
09/16/22 10:45 PM
09/16/22 10:45 PM
Posts: 3,096 Michigan
A727Tflite
In the Reman plants we regularly saw loose Help-coils.
Even when properly done there is no comparison between a helicoil and a Time-Sert.
Don’t waste your time with JB weld or plugs,etc.
Do it one time - use a Time-Sert.
[Re: A727Tflite]
#3078022
09/17/22 09:04 AM
09/17/22 09:04 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Do it one time - use a Time-Sert. He’s right ya know! https://www.timesert.com/
[Re: A12]
#3078027
09/17/22 09:30 AM
09/17/22 09:30 AM
Sniper
nowhere
Years ago, when I was in the Navy, I was stationed at an antenna overhaul shop for a while. When we ran into this kind of situation we would fill the hole with Decon Aluminum putty, re drill and re-helicoil it. If the helicoil is coming out it was improperly done. Ah Sniper I think you mean Devcon aluminum epoxy (great stuff BTW) not the mouse and rat poison Decon (Yeah it happens when we get elderly DAMHIK ) Mike Yeah, my keyboard has a flaky V key
[Re: moparx]
#3078207
09/17/22 08:49 PM
09/17/22 08:49 PM
TJP
Omaha Ne
Put a thread insert in it cheap, and uses a larger out side diam. than a helicoil. less than a buck at the hardware store. i was just going to say this ! ^^^^^ my local ACE hardware has a reasonable supply of these in common thread sizes and lengths, but if they don't have what i need, the ACE hardware in the next town over [20 miles] has a HUGE assortment ! Could you give a part # or post a pic? All I could find on their website was helicoils
[Re: TJP]
#3078281
09/18/22 07:44 AM
09/18/22 07:44 AM
Posts: 1,008 rust belt
Moparite
rust belt
[Re: TJP]
#3078295
09/18/22 09:00 AM
09/18/22 09:00 AM
Posts: 2,007 Apollo, PA.
B1MAXX
Apollo, PA.
Put a thread insert in it cheap, and uses a larger out side diam. than a helicoil. less than a buck at the hardware store. i was just going to say this ! ^^^^^ my local ACE hardware has a reasonable supply of these in common thread sizes and lengths, but if they don't have what i need, the ACE hardware in the next town over [20 miles] has a HUGE assortment ! Could you give a part # or post a pic? All I could find on their website was helicoils They have the ez-loc style in the hardware trays, you know the aisle with all the nut bolts and fasteners. They are sold individually. I don't think they put those items on the website.
[Re: volaredon]
#3078346
09/18/22 11:01 AM
09/18/22 11:01 AM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Torque to spec on a Transmission pan , why ?
I have my #s matching transmission missing a bolt for the pan - Same situation as yours
I just left it
Typical cork / rubber pan gasket , doesn’t leak a drop bolts just snug , no rtv
If yours is leaking , look above the Transmission pan gasket
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
