'62 B body Push Button Transmission #3077050
09/13/22 08:46 PM
09/13/22 08:46 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I have a '62 Fury with a /6 and push button tranny. I plan on putting in a 413 in the next year or so and want to keep the push button tranny. Sounds like the best way is to get a '65 big block tranny as it will have the slip yoke tail section but those are hard to come by. I found a '64 Chrysler 300 with a 383 and push button tranny here local that I can get fairly cheap. If I go that route I believe the two shift cables on my car (/6) will operate the '64 big block tranny, correct? Also, I should be able to use the '64 Chrysler driveline, with ball and trunnion, and shorten it for my '62, correct?
Re: '62 B body Push Button Transmission [Re: VITC_GTX] #3077070
09/13/22 10:03 PM
09/13/22 10:03 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
if you have the Park lever on the dash should be a bolt in.
Bummer as I have a 64 cable shift w driveshaft I need to find a new home for smile beer
Re: '62 B body Push Button Transmission [Re: VITC_GTX] #3077094
09/13/22 11:20 PM
09/13/22 11:20 PM
If the 300 has a console shifter those cables won't work on your push buttons, if it has the push buttons you should be good.
Those trannys are real sensitive to the adjustment of those cable shifters', one bolt hole can make it out of adjustment: shock:
I take the tranny pan off to adjust the shift cable, disconnect the retainer on the pin on the shift cable end that moves the arm that moves the manual valve in the valve body and then put the shifter arm in neutral and adjust the cable housing with the adjusting wheel so the pin drops perfectly into the hole in the shifter arm, perfectly every time
Have fun, take your time and look at it real hard before you start and make sure your very happy with the adjustment when you're done twocents scope wrench up
Re: '62 B body Push Button Transmission [Re: Cab_Burge] #3077405
09/15/22 07:45 AM
09/15/22 07:45 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The console shift vs pushbutton can be remedied. You need to swap the rooster comb, manual valve, and neutral safety switch from the /6 valve body. Simple swap.
Doug
Re: '62 B body Push Button Transmission [Re: dvw] #3077505
09/15/22 12:59 PM
09/15/22 12:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
IMO, it's easier to leave the console VB in place, use the PB cable and use the console adjustment procedure
Re: '62 B body Push Button Transmission [Re: Cab_Burge] #3077527
09/15/22 01:35 PM
09/15/22 01:35 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
This car is a bench seat car with dash mounted push button.
For clarification, my current /6 cables will work with the the '64 big block tranny, correct (same length, etc)?
Re: '62 B body Push Button Transmission [Re: John_Kunkel] #3077586
09/15/22 05:58 PM
09/15/22 05:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
John, wouldn't the larger groove in the cable allow for slop between the rooster comb and the cable itself? I've always been under the impression that the cable style, rooster comb, and manual valve must match .
Re: '62 B body Push Button Transmission [Re: dvw] #3077676
09/15/22 09:27 PM
09/15/22 09:27 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I believe the rooster comb and manual valve are different between console shift and PB. The longer "groove" would cause problems one direction or the other when changing gears as that added slop would result in the manual valve not moving unless that groove is fully engaged in the different attaching arm.
See what Mr Kunkel has to say wink
Re: '62 B body Push Button Transmission [Re: dvw] #3077815
09/16/22 01:11 PM
09/16/22 01:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The PB cable I recommended has the narrow groove and will fit properly in both the PB and console receivers. Again, the console/column adjustment procedure must be used when doing this.
Re: '62 B body Push Button Transmission [Re: John_Kunkel] #3077965
09/16/22 10:13 PM
09/16/22 10:13 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
So is the wider groove cable pictured normally used in a console shift car confused I'm just wondering what it's application was shruggy
Re: '62 B body Push Button Transmission [Re: TJP] #3078092
09/17/22 01:21 PM
09/17/22 01:21 PM
moparx Offline
moparx  Offline
doesn't the cable to rooster comb "adapter" have to match the cable used ? [wide groove vs narrow groove]
then the "adapter" pin od has to match the rooster comb hole id ? unless, of course, the od's of both adapter pins are the same, as well as the rooster comb's hole id's are the same.
i don't have anything of either, here to compare at the moment.
beer
Re: '62 B body Push Button Transmission [Re: TJP] #3078126
09/17/22 03:14 PM
09/17/22 03:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, the wide groove is used only on console/column. The wide groove allows for some over-travel when placing the shifter in Park.
Re: '62 B body Push Button Transmission [Re: moparx] #3078134
09/17/22 03:24 PM
09/17/22 03:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The "bullet" at the end of the cable is the same diameter for both and the narrow groove bullet will snap into the wide groove adapter but not vice versa.
Basically, the wide groove adapter has a spring at the bottom of its bore, the spring keeps the retaining wire pushed against one side of the groove during all operation until placed in Park then the slot allows the cable to over-travel slightly without kinking the cable. The shift cable performs no function in Park, it just shifts the shift valve into a dead space in the valve body casting...a secondary mechanism in the shifter operates the separate Park cable.
Re: '62 B body Push Button Transmission [Re: John_Kunkel] #3078204
09/17/22 08:26 PM
09/17/22 08:26 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
thank you smile
Re: '62 B body Push Button Transmission [Re: John_Kunkel] #3078340
09/18/22 10:52 AM
09/18/22 10:52 AM
moparx Offline
moparx  Offline
thank you John ! up bow
beer
