Re: NO AXLE PACKAGE FOR E-BODY HEMI
[Re: 71redcuda]
#3075529
09/08/22 03:00 PM
09/08/22 03:00 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
No axle package would be a 3.23 gear and I believe with a hemi it would have had a sure grip as standard .
[Re: 6bblgt]
#3075627
09/08/22 09:06 PM
09/08/22 09:06 PM
Posts: 21,522 N.E. OHIO, USA
A12
N.E. OHIO, USA
1970 Challenger R/T 3.23:1 OPEN is the STANDARD gear ratio & was not dependent on the engine
the OPTIONAL HEMI engine did not change or require any additional rear axle OPTIONS
the fender tag would not indicate if the subject HEMI R/T was 3.23 OPEN or 3.23 with the OPTIONAL Sure-Grip (~$42) - it would be noted on the window sticker and broadcast sheet Funny but it was true at least for a '68 Hemi Road Runner that a friend bought new back in '68. Bare bones no radio, rubber floor mat, RM21, column automatic. I've told the story before when back in '69 my friend was tuning my '69 RR and had the distributor out and on the Sun distributor machine when I got a call that my older sister had no way to get to work and needed me to take her there. My friend said "take my (Hemi) Road Runner. I jumped in it, took off to pick up my sister. I picked her up and jumped on the throttle and it lit up and I looked in the inside rear view mirror and ONLY ONE TIRE MARK! Got back to my friends shop and asked if something was wrong with the diff and he said, "nothing wrong just the standard 3.23 OPEN 8-3/4". My '69 383 RR that he was working on I ordered it with the 3.91 axle package, 727, Air Grabber etc. so I was shocked the Hemi RR had a 3.23 OPEN axle??? Fast forward and a local friend gets a numbers column auto '68 Hemi RR and when he first got it we were talking and he says to me "Mike you're never going to believe this but this Hemi RR has ........." Before he could get the words out, I say " A 3.23 OPEN 8-3/4 rear axle" "How the #3LL did you know that????" he says? "Long story" I said (Side note on how we think we know everything even when we're young. When my friend back in '69 with the '68 Hemi Road Runner pulled the distributor out of my '69 383 RR (727) he was sure I got hosed by the dealer and was thinking one of the mechanics stole my original distributor probably when they did the dealer prep. He was sure it should have had a dual point distributor instead of the single point he pulled out of it to tweak. Nope the automatic 383 RR's had a single point distributor. I was a little upset until I checked the specs, no biggie ) Mike
[Re: A12]
#3075718
09/09/22 09:11 AM
09/09/22 09:11 AM
Posts: 12,144 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Having had several '71 GTXs, I was always surprised that they had the heavy duty suspension and torque boxes but only an open rear standard. Must have been a way to get a couple more bucks for the SG option while keeping the base sticker price as low as possible.
Just seems weird for muscle cars to be peg legs especially given the fact that they were so traction compromised to begin with. Did the other manufacturers do the same thing?
Master, again and still
[Re: DaveRS23]
#3075789
09/09/22 01:03 PM
09/09/22 01:03 PM
Posts: 17,517 Las Vegas, NV
6bblgt
Las Vegas, NV
............................ Did the other manufacturers do the same thing? YES
[Re: 6bblgt]
#3075857
09/09/22 05:55 PM
09/09/22 05:55 PM
A12
N.E. OHIO, USA
............................ Did the other manufacturers do the same thing? YES IMO not only for economics but what if the factory guessed wrong on what the customer wanted for an axle ratio? I would think that out west with many open roads and highways an automatic with a 4.10 ratio for travel or daily long distant driving is not so ideal. Also my friend with the bare bones '68 Hemi Road Runner got it bare bones because he drag raced and had a 4.56 complete axle sitting in the shop for some reason And yes I know that the 4-speeds came with a standard 3.54 Dana axle (My '69 4spd GTX has that). A 3.23 axle ratio with Sure-Grip was really great and very nice to drive in my '68 Road Runner (383) and at 55-70 mph it was "pleasant" enough for my wife and family going cruising. $$$ and application or do like I did back in '69 when my dad gave me the look as the salesman asked if I wanted the standard 3.23 open axle package and I said "No I want the optional 3.91 Sure-Grip" and turned to my (co-signing) dad and said "I want and need it for the hills and snow dad" with a slight grin. (lived in southwestern PA at the time). He knew as he was a mechanic and IMO gear head too. . Mike
[Re: 6bblgt]
#3075884
09/09/22 07:54 PM
09/09/22 07:54 PM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
............................ Did the other manufacturers do the same thing? YES Yep, my 67 S/S 396 Chevelle auto had a 12 bolt high 2 something open rear, and the 70 Challenger HP 383 4 speed had the 3.23 open rear. Then my 70-1/2 Z28 auto had a 4.10 posi 12 bolt. Basically if ordered it had the posi, off the lot, no
[Re: A12]
#3075890
09/09/22 08:08 PM
09/09/22 08:08 PM
6bblgt
Las Vegas, NV
...................... And yes I know that the 4-speeds came with a standard 3.54 Dana axle (My '69 4spd GTX has that). ........... the DANA60 was a MANDATORY extra-cost OPTION on 4-speed 440 & HEMI cars (the 4-speed was no-charge '68 & '69)
