1999 5.9L Fuel Sync
#3072695
08/30/22 04:58 PM
08/30/22 04:58 PM
Posts: 1,177 Santa Ana, CA
DustyChicken
Santa Ana, CA
I have a customer with a 1999 B Van with a 5.9. We're having issues getting the fuel synchronization set. I have an Autel scanner that can do the Set Synchronization routine, and I can see the degrees.
The setting keeps bouncing around, usually a ten degree range. -2 to +8 for example. It also fairly regularly spikes to +23 degrees. I can get the distributor close, but it never sets into one place. If I rev the engine to 1000RPM the degrees freeze on my scanner and won't update until I let the RPMs come down again and restart the routine.
The customer replaced the timing change thinking that it was too slack and allowing the cam to bounce, but that didn't change anything. New aftermarket cam sensor in the distributor. New crank sensor. He did file down the crank tone ring because the previous crank sensor was set too tight and boogered it up a little. His other mechanic said it looked fine after filing, and I can see a steady RPM graph on my scanner. I took out the distributor and checked it for wear, there's no play in the shaft and the drive gear in the block looks okay. I'm not sure if it's properly timed to no. 1 cylinder TDC though.
Any ideas?
Re: 1999 5.9L Fuel Sync
[Re: DustyChicken]
#3072722
08/30/22 05:41 PM
08/30/22 05:41 PM
Posts: 3,060 N.W. Florida
Fat_Mike
N.W. Florida
From the 2001 Ram Service Manual: Checking Distributor Position To verify correct distributor rotational position, the DRB scan tool must be used. WARNING: WHEN PERFORMING THE FOLLOWING TEST, THE ENGINE WILL BE RUNNING. BE CAREFUL NOT TO STAND IN LINE WITH THE FAN BLADES OR FAN BELT. DO NOT WEAR LOOSE CLOTHING. (1) Connect DRB scan tool to data link connector. The data link connector is located in passenger compartment, below and to left of steering column. (2) Gain access to SET SYNC screen on DRB. (3) Follow directions on DRB screen and start engine. Bring to operating temperature (engine must be in “closed loop” mode). (4) With engine running at idle speed, the words IN RANGE should appear on screen along with 0°. This indicates correct distributor position. (5) If a plus (+) or a minus (-) is displayed next to degree number, and/or the degree displayed is not zero, loosen but do not remove distributor holddown clamp bolt. Rotate distributor until IN RANGE appears on screen. Continue to rotate distributor until achieving as close to 0° as possible. After adjustment, tighten clamp bolt to 22.5 N·m (200 in. lbs.) torque. The degree scale on SET SYNC screen of DRB is referring to fuel synchronization only. It is not referring to ignition timing. Because of this, do not attempt to adjust ignition timing using this method. Rotating distributor will have no effect on ignition timing. All ignition timing values are controlled by powertrain control module (PCM). After testing, install air cleaner assembly.
[Re: DustyChicken]
#3072810
08/31/22 04:11 AM
08/31/22 04:11 AM
Guitar Jones
Correct synching procedure needs to be performed, but there was a TSB out about the distributor/oil pump drive gear bushing having excessive wear.
[Re: Guitar Jones]
#3072813
08/31/22 06:51 AM
08/31/22 06:51 AM
Posts: 984 rust belt
Moparite
rust belt
I'm not sure if it's properly timed to no. 1 cylinder TDC though. So check it! Don't go by the marking because the outer ring on the balencer because it may have moved. Check you are on TDC #1 cylinder on the COMPRESSION STROKE Then set the distributor like this...
[Re: Moparite]
#3072831
08/31/22 08:42 AM
08/31/22 08:42 AM
Posts: 18,420 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I'm not sure if it's properly timed to no. 1 cylinder TDC though. So check it! Don't go by the marking because the outer ring on the balencer because it may have moved. Check you are on TDC #1 cylinder on the COMPRESSION STROKE Then set the distributor like this... That just gets it in the ball park so it will run. Signal needs to be correctly set with a scan tool.
[Re: Moparite]
#3072860
08/31/22 10:13 AM
08/31/22 10:13 AM
DustyChicken
Santa Ana, CA
I'm not sure if it's properly timed to no. 1 cylinder TDC though. So check it! Don't go by the marking because the outer ring on the balencer because it may have moved. The car is currently at my customer's house. This is some side work for me and a project car for him. I'll check it next time we get together. The distributor rotor did line up with that notch when the balancer was at TDC, though. Correct synching procedure needs to be performed, but there was a TSB out about the distributor/oil pump drive gear bushing having excessive wear. That is one of my theories, since the timing jumps around so much. The motor is a reman, not sure who built it. Who knows if they replaced the bushing or properly reamed it with the correct tool. Do you have the TSB number? Thanks for all the responses, it's given me some avenues to explore.
[Re: DustyChicken]
#3072957
08/31/22 04:23 PM
08/31/22 04:23 PM
Fat_Mike
N.W. Florida
I'm not sure if it's properly timed to no. 1 cylinder TDC though. So check it! Don't go by the marking because the outer ring on the balencer because it may have moved. The car is currently at my customer's house. This is some side work for me and a project car for him. I'll check it next time we get together. The distributor rotor did line up with that notch when the balancer was at TDC, though. Correct synching procedure needs to be performed, but there was a TSB out about the distributor/oil pump drive gear bushing having excessive wear. That is one of my theories, since the timing jumps around so much. The motor is a reman, not sure who built it. Who knows if they replaced the bushing or properly reamed it with the correct tool. Do you have the TSB number? Thanks for all the responses, it's given me some avenues to explore. Apparently that's normal(?) in the OBD2 controlled Magnums. Read the last couple pages of this thread: https://board.moparts.org/ubbthread...43375/10/super-duper-mpg-318-part-2.html
[Re: Fat_Mike]
#3073138
09/01/22 06:50 AM
09/01/22 06:50 AM
Moparite
rust belt
That just gets it in the ball park so it will run. Signal needs to be correctly set with a scan tool. Actually what i posted is in the service manual, With a new timing chain it should work fine.
