Re: New COPO 572 inch Camaro
[Re: Cab_Burge]
#3072757
08/30/22 07:45 PM
08/30/22 07:45 PM
Posts: 1,389 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Is this an GM, Chevy, production car or a special package for drag racing only like the 1968 Hurts Hemi Darts and Baracuda? It's Chevy's program comparable to the Drag Pak Challengers ==> LINK TO COPO PAGE
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Cab_Burge]
#3072759
08/30/22 07:48 PM
08/30/22 07:48 PM
Posts: 1,918 South Bend
John Brown
South Bend
If it's anything like their COPO car production from recent history, they only build 69 total body's per year, but they are available with several different engine cubic inch / supercharged / NA engine combinations.
[Re: topside]
#3072858
08/31/22 09:06 AM
08/31/22 09:06 AM
Posts: 3,573 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I keep thinking that NHRA should have a class that allows a 14x32 tire for the FS cars, and it could be the new Pro Stock. At least there would be some variety in the class, and more like the early days; and less like semi-ProMod. There is a new class in the works called Factory X that uses big tires, Factory Shootout engines, stick shifts and full chassis. Several cars are being build but as far as I know none are finished yet. The can run Comp Eliminator, perhaps some will run in exhibition late this year or early next year. This link describes the class: https://www.nhra.com/news/2021/factory-x-presented-holley-exhibition-class-debut-during-2022-season
[Re: 340Cuda]
#3072863
08/31/22 09:22 AM
08/31/22 09:22 AM
Brad_Haak
Loudoun County, VA
"... the FX category will bridge the gap between Factory Stock Showdown and Pro Stock Camaro."Cool... but how much longer are the factories going to support Factory Stock efforts w/ the general move towards EV? Re original topic, I love the COPOs, Drag Paks and Cobra Jet Factory Stock cars. Will never own one, but doesn't stop me from
[Re: Brad_Haak]
#3072879
08/31/22 10:45 AM
08/31/22 10:45 AM
Posts: 20,387 Park Forest, IL
slantzilla
Park Forest, IL
Geoff Turk posted the other day his F/X car is about 80% done.
He ran his old Blackbird in Comp last weekend at Bowling Green.
[Re: EvilB1Dart]
#3072912
08/31/22 12:33 PM
08/31/22 12:33 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I think NHRA rated it at 500HP, so the car is going to struggle to perform at the necessary weight for FS. The carb'd crate makes 720, but the EFI version has to breath through a 90mm throttle body
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: justinp61]
#3078044
09/17/22 09:35 AM
09/17/22 09:35 AM
Posts: 31,259 Oregon
AndyF
No, there are just two lines, one from each valve cover. It is just a remote breather with a catch can. This gives you a view of the other side.
[Re: AndyF]
#3078237
09/17/22 09:41 PM
09/17/22 09:41 PM
AndyF
I tweaked the EFI tune a little bit and the car ran a 9.439 @ 141.08 this morning. The owner also installed the factory fresh air inlet on the throttle body that pulls air in directly from the scoop. We had been told that the inlet scoop was worth at least a tenth. One racer said it was worth two tenths. So he has picked up 4 tenths since we started tuning. The air was really good this morning so that was part of it.
[Re: AndyF]
#3078306
09/18/22 08:34 AM
09/18/22 08:34 AM
Brad_Haak
Loudoun County, VA
[Re: AndyF]
#3078628
09/19/22 04:18 AM
09/19/22 04:18 AM
Posts: 570 UK
rb446
UK
And there's your 800fwhp in that air
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
