Re: R134 converted ac systems charge level ??? [Re: gtx6970] #3236218
06/01/24 11:22 PM
06/01/24 11:22 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Did the 36 oz do what you wanted now that you’ve used it awhile? I’m getting ready to recharge after a leak. 36 worked, but it did freeze up on max cool. Worked well on regular cool. I didn’t get to put a gauge on the vent before it leaked out the schrader that didn’t get changed. 69 GTX with all factory style parts.
I want my fair share
Re: R134 converted ac systems charge level ??? [Re: SomeCarGuy] #3236267
06/02/24 11:49 AM
06/02/24 11:49 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
For those with doubts about the refrigerant conversion… I took pics from a Mopar mag I have where an article was posted with all the procedurement. Althought I think missed to take the pic to the last page, but the basics are still there
Album here:
https://postimg.cc/gallery/ChwjbjB
I made it and it worked great.
Didn’t changed the hoses because they were “seasoned”. Just changed when got one of them broken.
Re: R134 converted ac systems charge level ??? [Re: gtx6970] #3236272
06/02/24 12:39 PM
06/02/24 12:39 PM
Arizona
3
340rag Offline
340rag  Offline
Arizona
Yeah, the 80% rule is a good guideline for converting R12 to R134a. So if your manual says 3lbs 6oz of R12, then 2.68 lbs of R134a should be about right.
Re: R134 converted ac systems charge level ??? [Re: SomeCarGuy] #3236508
06/03/24 12:49 PM
06/03/24 12:49 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Yes.
I had it blowing low 40s at center vent outlet
