Re: Valve cover gasket sealant
[Re: 6PAX]
#3070702
08/23/22 10:19 AM
08/23/22 10:19 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
You shouldn't need any sealant. If you have decent valve covers and good gaskets for the application, it shouldn't leak. A lot depends on the heads and valve covers you're using.
[Re: 6PAX]
#3070752
08/23/22 12:56 PM
08/23/22 12:56 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
I like to use an adhesive to hold the gasket to the cover, and then a thin film of oil or grease on the head to allow the cover and the gasket to be pulled off later on, hopefully without ripping the gasket so they can be reused a few times.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3070771
08/23/22 01:41 PM
08/23/22 01:41 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
I like to use an adhesive to hold the gasket to the cover, and then a thin film of oil or grease on the head to allow the cover and the gasket to be pulled off later on, hopefully without ripping the gasket so they can be reused a few times. Same here
[Re: moparx]
#3070846
08/23/22 05:02 PM
08/23/22 05:02 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
From everything said above, the most critical factor is FLATNESS.. the cover and the head casting. Next, is the clamping load... must be equal and not excessive.. excessive clamp load causes the gasket to split... as well as using grease or oil upon clamping.
Always best installed DRY, especially rubber type gaskets. The gasket does the sealing... not the chemical.
I worked for many long years for a major gasket company and was responsible for all the installation instructions.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#3070930
08/23/22 10:40 PM
08/23/22 10:40 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
Glue the gasket to the cover with Gorilla Snot (3m trim adhesive). Oil the other side if the head isn't already oily (usually is lol)
