Converting from Lean Burn to standard ignition #3068940
08/17/22 06:05 PM
08/17/22 06:05 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
I have a 1980 Gran Fury squad car with a 360 4bbl Lean Burn. I have a electronic ignition conversion kit and non lean Burn thermoquad.
So my question is do I use the wiring for the computer or do I just start from scratch? What is the best way to wire up a electronic conversion from Lean Burn.
Thank you for any help given
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Converting from Lean Burn to standard ignition [Re: TX9H6E4CUDA] #3068973
08/17/22 07:56 PM
08/17/22 07:56 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I did this many years ago on a 76 Cordoba. It was pretty straight forward and simple. Took me under an hour. Go to the tech archives and look up elec topics. There are diagrams to help.
Re: Converting from Lean Burn to standard ignition [Re: elmor353] #3069241
08/18/22 02:41 PM
08/18/22 02:41 PM
5thAve Offline
5thAve  Offline
There's no real doing it from scratch, go back to the starter relay and leave the rest alone.
1979 had a ballast resistor in the setup. If 1980 still had the ballast resistor too half the work is already done for you.
Re: Converting from Lean Burn to standard ignition [Re: TX9H6E4CUDA] #3069247
08/18/22 02:51 PM
08/18/22 02:51 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Mopar performance engine book has the procedure for your car and many others
step by step.
it is in the book, maybe somewhere on the web
Re: Converting from Lean Burn to standard ignition [Re: TX9H6E4CUDA] #3069452
08/19/22 09:34 AM
08/19/22 09:34 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
On my 79 Cordoba, my goal was to keep it original looking. I had a spare Lean Burn box, gutted it and cut the bottom to add clearance for the orange box connector. I cut off the old Lean Burn ECU plug off the circuit board and soldered to the pigtail for the electronic ignition. All the wiring needed is in the factory wire to the lean burn.
I was concerned about heat, but I think the high volume of air moving around keeps the orange box cool enough. This was done 20 years ago and I used to use the car pretty much every day back then. In theory I could swap back in another lean burn module and old distributor and go back to stock, not that I want to.
Re: Converting from Lean Burn to standard ignition [Re: njmopar] #3069453
08/19/22 09:43 AM
08/19/22 09:43 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Not an absolute, but you get the full affect if you change the carb to a pre-leanburn version. The vacuum signal is opposite from the std. ignition w/vacuum advance.
I have one car I kept the leanburn hooked up, and ran a dizzy with VA and changed the carb ( as the car had sat for years and the carb was varnished up ). What a difference.
I have actually had good experiences with lean burns. I've owned 20+ Magnums and a few Dobas over the years, and have not had much trouble. Some of the Magnums I've bought have had the change done already. I certainly don't change it back.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Converting from Lean Burn to standard ignition [Re: Magnumguy] #3069492
08/19/22 10:55 AM
08/19/22 10:55 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I have actually had good experiences with lean burns. I've owned 20+ Magnums and a few Dobas over the years, and have not had much trouble. Most of the Magnums I've bought have had the change done already. I certainly don't change it back.
Yes, the lean burn carbs are built to be LEAN ! . . . Changed the lean burn off the 77 New Yorker I had gotten, and used a TQ I had rebuilt, that was from a 74 440 . . . what a difference for sure !!
Re: Converting from Lean Burn to standard ignition [Re: TX9H6E4CUDA] #3069640
08/19/22 06:05 PM
08/19/22 06:05 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
When they work, they work pretty well. When they go bad, chug, chug, chug. I had one go bad.
Pic of the 80 A38 Gran Fury PLEASE up Love those E58's!
Facts are stubborn things.
Re: Converting from Lean Burn to standard ignition [Re: TX9H6E4CUDA] #3069741
08/19/22 10:45 PM
08/19/22 10:45 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I did a Pertronix II swap using a single point vac adv Chrysler dist / Pertronix II kit 91381A and Pertronix Flame Thrower coil as the starting base, changed the intake out for an Edelbrock 4 bbl manifold/Holley 600 CFM on a 1980 5th Ave, just trash all the lean burn junk, no ballast resistor required, the Pertronix is very straight forward, you just need the hot ignition (run) lead..... the rest can hit the trash can
Re: Converting from Lean Burn to standard ignition [Re: DAYCLONA] #3069823
08/20/22 11:03 AM
08/20/22 11:03 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Do you mean the mopar performance one? It has everything you need.
https://www.amazon.com/Mopar-Small-Electronic-Ignition-Distributor/dp/B01FAYBAQ8
The lean burn distributor has two pick ups in it witch you are replacing so it won't be in use. Just wire up the kit.
Re: Converting from Lean Burn to standard ignition [Re: Moparite] #3069892
08/20/22 02:04 PM
08/20/22 02:04 PM
Great White North
W
Wheeler Offline
Wheeler  Offline
W
Great White North
Here's a link to the instructions for installing the Mopar Performance Electronic Ignition Conversion Kit:
https://www.mymopar.com/downloads/elecignconv.pdf
Re: Converting from Lean Burn to standard ignition [Re: Wheeler] #3069920
08/20/22 03:48 PM
08/20/22 03:48 PM
E
elmor353 Offline
elmor353  Offline
E
Sometimes the answers on this forum can be really confusing. Everything he needs to know is in the tech archives under "elec topics".
Re: Converting from Lean Burn to standard ignition [Re: elmor353] #3070120
08/21/22 11:07 AM
08/21/22 11:07 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Also might be helpful if you post links! Didn't see any wiring/instillation links there or did i miss it?
http://www.moparts.org/Tech/
http://www.moparts.org/Tech/Archive/elec.html
Re: Converting from Lean Burn to standard ignition [Re: Moparite] #3070125
08/21/22 11:35 AM
08/21/22 11:35 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
http://www.moparts.org/Tech/Archive/elec/3.html
