Re: Cam Core Dia for Big Lift [Re: Cab_Burge] #3069580
08/19/22 02:50 PM
08/19/22 02:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We see over .040" of lost lift at the valve from deflection even with a 60MM cam, individual steel rockers and single shafts(two bolts per rocker three per stand) with as big a pushrod as we can squeeze in it on the SBC in the Vette. Point is deflection is always there and the bigger core helps. Be great if we could get a 9 cam bearing block that also helps a ton. But only going to find that in a couple applications. We have planned to go to a clamshell bearing so we can go to a bigger lobe to gain the lift we think we need to compete in NA10.5 given the deflection losses we see. We simply cannot put a bigger lobe on the cam now and clear the 60MM bearing..Point is deflection is a real thing, the bigger the stick the ore of it you will encounter.
Re: Cam Core Dia for Big Lift [Re: Cab_Burge] #3069589
08/19/22 03:13 PM
08/19/22 03:13 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Originally Posted by Cab_Burge
Your example is perfect showing not all parts respond and perform the same work
What brand did you buy and use?
Did you have the rear cam bearing enlarge also for the 55MM or leave it stock and use a stock Babbit type rear stock bearing their?
Are you asking me? Yes, all of my journals are 55MM roller bearing with an enlarged cam plug register also.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Cam Core Dia for Big Lift [Re: 6PKRTSE] #3070341
08/22/22 12:11 AM
08/22/22 12:11 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I think once you start getting near 0.500" of lobe lift, going up to a larger core is a must. If you are paying for a custom core, plus enlarging the tunnel, it wouldn't make sense to not go up to 60 mm. There is a conversion babbit bearing that allows the use of a 65 mm core in a roller 60 mm tunnel as well. Or go up again using clamshell bearings, which gets spendy.
Alan Jones
