Re: 727 bolt size? Thread in trans
[Re: elmor353]
#3067677
08/13/22 04:19 PM
08/13/22 04:19 PM
Posts: 19,426 north of coder
moparx
the holes that are circled are for the guide pins. the other [larger] threaded holes are 7/16-14 [course as has been mentioned] and the smaller holes are 1/4-20 thread. the top threaded hole above the starter gets a stud that is 7/16-20 [fine] thread the starter hangs on. there is approximately 1 1/2" of stud hanging out of the bellhousing. [calibrated eyeball measurement ] i just double checked this on a 727 on the shelf.
[Re: moparx]
#3067711
08/13/22 06:23 PM
08/13/22 06:23 PM
Posts: 4,732 Florida
BDW
Well, I may have circled the wrong holes. What I'm sure of, is the 4 top holes are not threaded. The 2 holes I need bolts for are threaded, they insert from engine side and thread into trans, and are larger than top 4 bolts. Trans is mated to engine, I know this because I fought it for 2 hours getting those guide pins aligned. Dust cover is installed, just these last 2 spots are missing bolts.
Found this pic, not mine, but this is starter side
[Re: BDW]
#3067856
08/14/22 02:19 PM
08/14/22 02:19 PM
moparx
the top four unthreaded holes are for the 3/8-16 thread bolts that thread into the engine block. these, you know. the two threaded holes you need bolts for are 7/16-14 thread. however, i am not sure of the length of these. "possibly" around 1 1/4" or 1 1/2" long. i'm just guessing on the length of these bolts. i believe the starter bolt threads are 5/8-11 thread. hope this helps out.
[Re: moparx]
#3068089
08/15/22 09:34 AM
08/15/22 09:34 AM
Posts: 75,026 U.S.S.A.
JohnRR
U.S.S.A.
the top four unthreaded holes are for the 3/8-16 thread bolts that thread into the engine block. these, you know. the two threaded holes you need bolts for are 7/16-14 thread. however, i am not sure of the length of these. "possibly" around 1 1/4" or 1 1/2" long. I'm just guessing on the length of these bolts. i believe the starter bolt threads are 5/8-11 thread. hope this helps out. Starter bolts are also 7/16 , otherwise what you posted is correct.
[Re: moparx]
#3068182
08/15/22 02:03 PM
08/15/22 02:03 PM
JohnRR
U.S.S.A.
John, i stand corrected ! i knew the starter bolts are 7/16 thread. i don't know why i stated they were 5/8". my mind was obviously wandering around in the "cobwebs" and got distracted ! i will gladly take any punishment deemed necessary for my bad behavior............. 5/8 to get it out ...
