Originally Posted by 451Mopar
Either. Likely stock type since I have a few new sets on the shelf.
The green bearing do move the axles inward slightly and if the carrier has the thrust block it often will pre-load the green bearings.
You can remove the thrust block, or grind a bit off the end of the axle(s), or add a shim between the brake backing plate and axle flange.
Thrust blocks require differential disassembly if it's anything but a one legger , cutting the axle or shimming the axle out is the easier job.
