Metal R 134 service port caps
#3066042
08/07/22 01:26 PM
08/07/22 01:26 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
Re: Metal R 134 service port caps
[Re: TJP]
#3066114
08/07/22 07:14 PM
08/07/22 07:14 PM
Posts: 1,894 Harriman NY
71GTX471
Harriman NY
The caps are only designed to seal dirt/moisture out not seal a leaking Schrader valve off.
[Re: TJP]
#3066199
08/08/22 11:19 AM
08/08/22 11:19 AM
Posts: 19,599 north of coder
moparx
what about putting a small o-ring [that just fits] inside the cap ? or use a leather punch to make a gasket out of an old inner tube [using the "hole" piece created by the punch] ? that may seal the cap to the fitting somewhat. just tossing something out there.
[Re: Moparite]
#3066226
08/08/22 01:08 PM
08/08/22 01:08 PM
TJP
Omaha Ne
It wasn't a scam, And if you are worried about leakage replace your old valves. Never had a issue with them. OK But 30 years ago R134 was the solution, Now it is deemed harmful once again Using metal caps with seals would've provided secondary containment for a refrigerant that is now being replaced due to it's effects on the environment. Sounds too familiar to me I have my own theories on global warming and it has little to do with freon
[Re: moparx]
#3066229
08/08/22 01:14 PM
08/08/22 01:14 PM
TJP
Omaha Ne
what about putting a small o-ring [that just fits] inside the cap ? or use a leather punch to make a gasket out of an old inner tube [using the "hole" piece created by the punch] ? that may seal the cap to the fitting somewhat. just tossing something out there. Most of the caps do have a Silicone/Viton/rubber type seal but the caps being plastic and exposed to heat were a poor choice IMO. I've found some slip over covers but I was curious if anyone knew of a source for metal caps
[Re: TJP]
#3066391
08/08/22 10:09 PM
08/08/22 10:09 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
what about putting a small o-ring [that just fits] inside the cap ? or use a leather punch to make a gasket out of an old inner tube [using the "hole" piece created by the punch] ? that may seal the cap to the fitting somewhat. just tossing something out there. Most of the caps do have a Silicone/Viton/rubber type seal but the caps being plastic and exposed to heat were a poor choice IMO. I've found some slip over covers but I was curious if anyone knew of a source for metal caps Never seen metal caps for 134 but then I never seen a failure with the plastic ones in over 35 years Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
