Re: Which 4 BBL manifold & carb 4 project-pics attached?
[Re: RapidRobert]
#306551
05/05/09 06:58 PM
05/05/09 06:58 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
The top one has the thermostat housing clocking different for an A/C application. I'd consider a 1&3/8" primaries thermoquad from Demonsizzler.
By the way, O tried to PM him to see what a carb would cost and his inbox is full. I will try a thread notification.
[Re: DEMONSIZZLER]
#306554
05/06/09 01:52 AM
05/06/09 01:52 AM
Posts: 5,449 Woodbridge,CA
NAS Backyard
Woodbridge,CA
Dave, the inside of that engine looks great, I wouldn't touch it. If you go with a TQ I got one I will give you, free.
1970 Challenger Ragtop 426 4 speed
1961 Olds 88 2 dr Sedan 394 4 speed GVOD
1968 Pontiac Firebird 428 4 speed
2000 Ford F-150
2002 HD Roadking
1961 Licence Plate collection
1995 Buick Roadmaster
www.nogreenautolaws.com
[Re: NAS Backyard]
#306555
05/06/09 02:51 AM
05/06/09 02:51 AM
Posts: 386 Maryland
reno340
Maryland
I would just use the non-EGR manifold and get a spacer and put an Edelbrock on it. You will probably hear some on here say it won't work out but I added the spacer and put an Edelbrock on my '72 340 and it runs fine. Not a killer combo but the carb runs fine and reliably. If you don't want to do that just put on a spread bore Holley (won't need the spacer)
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: Which 4 BBL manifold & carb 4 project-UPDATED?
[Re: RUMBLON]
#306562
05/07/09 09:15 PM
05/07/09 09:15 PM
Posts: 386 Maryland
reno340
Maryland
Its obviously too low and hits the manifold on the side. Can a spacer be used to lift it???
Dave, You also need the spacer because the manifold is for a spread bore carb (primary butterflies are smaller than the secondaries) and the Eddy is a square bore (all 4 butterflies are the same size)
[Re: RUMBLON]
#306563
05/08/09 02:12 PM
05/08/09 02:12 PM
Posts: 826 Stone Mt, GA.
DEMONSIZZLER
super gas
super gas
Stone Mt, GA.
OK, so here are the valve covers and manifold that I decided to use, the non EGR older one.
I also found this in my parts stash, its an Edelbrock carb. has the numbers #1407 on the side and looks like 0236???? any idea what CFM this is and why wont this work on here??? Its obviously too low and hits the manifold on the side. Can a spacer be used to lift it???
And I know the engine is not original, but what valve covers appear more original for this truck??? I painted and sand blasted both sets.
Way too much square-bore CFM for your 318! You would only need either a 500 or 600 cfm square-bore or an 800 cfm T.Q., David.
