66 Coronet engine ground #3064477
08/01/22 08:04 PM
08/01/22 08:04 PM
New England
Tech Instructor Offline OP
New England
66 Coronet 383 where is the engine to firewall ground attached
Re: 66 Coronet engine ground [Re: Tech Instructor] #3064480
08/01/22 08:08 PM
08/01/22 08:08 PM
Mine is under the voltage regulator but it may not be stock shruggy
Maybe this would get better results in the restoration forum scope twocents
Re: 66 Coronet engine ground [Re: Cab_Burge] #3064482
08/01/22 08:10 PM
08/01/22 08:10 PM
New England
New England
Thanks Cab
Re: 66 Coronet engine ground [Re: Tech Instructor] #3064490
08/01/22 08:37 PM
08/01/22 08:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1966 satellite,
right in between ballast resistor and voltage regulator
Re: 66 Coronet engine ground [Re: gtx6970] #3064534
08/02/22 12:16 AM
08/02/22 12:16 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
...and make sure you scrape a little paint off the contact area, to get a good ground.
Re: 66 Coronet engine ground [Re: topside] #3064751
08/02/22 08:52 PM
08/02/22 08:52 PM
New England
New England
Thanks everyone where does it attach on the engine side?
Re: 66 Coronet engine ground [Re: Tech Instructor] #3064756
08/02/22 08:57 PM
08/02/22 08:57 PM
Wherever you want it up wrench grin
Or did you mean where is it hooked up in the stock location on the engine? confused
Re: 66 Coronet engine ground [Re: Tech Instructor] #3064768
08/02/22 09:16 PM
08/02/22 09:16 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
the further most rearward intake bolt. pass side . Sometimes they will have a separate bolt in a threaded hole just rearward of the intake
Re: 66 Coronet engine ground [Re: gtx6970] #3065544
08/05/22 05:55 PM
08/05/22 05:55 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Please do not scrape any paint off the firewall.
The grounding happens under the bolt head to the eyelet, and the bolt threads in the hole.
Scraping paint will just cause rust and corrosion, and futur problems.
How many factory body grounds had the paint scraped off? None, and they made it through the warranty and decades beyond without any trouble.
