Re: What offset dials do I need?
[Re: Clanton]
#3064320
08/01/22 12:05 PM
08/01/22 12:05 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
I used a base like that for my ultra bell and it worked fine just the total ht of the gage is smaller than the hole and enough movement to measure the min/max. Ok thanks!!!
[Re: 70RT Charger]
#3064523
08/01/22 10:43 PM
08/01/22 10:43 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have a tool I designed that might work for you. It has a 6 bolt flange and I use for all my bellhousings. If you want to use it send me a PM with your address I'll ship it to you. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3064583
08/02/22 09:48 AM
08/02/22 09:48 AM
70RT Charger
eastern,Ky
I have a tool I designed that might work for you. It has a 6 bolt flange and I use for all my bellhousings. If you want to use it send me a PM with your address I'll ship it to you. Gus That looks sweet. I already have this straight shaft coming my way that I think will work a lot better. If it doesn’t I’ll be shooting you a PM. Thanks!!!!
[Re: moparx]
#3064685
08/02/22 03:37 PM
08/02/22 03:37 PM
70RT Charger
eastern,Ky
the indicator you have appears to have the same size shafts. [remember, my eyes are not the best any more] can't you attach your indicator to the main shaft using the clamps you have ? No it won’t attach. I’ve already tried it. I probably could have cut it off and rigged it up somehow but I had other stuff going on and didn’t have time to mess with it. The indicator I have now will work on this shaft I’m getting but wanted an extra one.
[Re: moparx]
#3064829
08/03/22 08:43 AM
08/03/22 08:43 AM
Posts: 10,044 MN
JERICOGTX
MN
Thank you for that. I need my own...
69 GTX
68 Road Runner
[Re: Stanton]
#3064875
08/03/22 11:16 AM
08/03/22 11:16 AM
70RT Charger
eastern,Ky
I have the same one you ordered and it works just fine. Good deal. Thanks!!!
[Re: Stanton]
#3064881
08/03/22 11:32 AM
08/03/22 11:32 AM
Posts: 4,091 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
The base does not need to be mounted dead center on the crank - I don't know why people think it does. You can mount it right out on the flat surface of the flywheel, it doesn't matter. The dial indicator will be in the hole and all that matters is that IT is roughly level with the flat surface of the bell and, for lack of a better term, square to the edge of the hole. And it also has to point in the direction of the base. X2
[Re: AndyF]
#3064882
08/03/22 11:33 AM
08/03/22 11:33 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
Here is the set up that I use. I had to build it myself since I couldn't find anyone who sold a tool that worked with my parts. Do you sell the base you made ?
