Is a 70 Airgrabber switch same size as a 71-2? #3061871
07/23/22 03:24 PM
07/23/22 03:24 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
As title says: Is the physical size of a 70 switch the same as a 71-2 vacuum switch?
So all that would be needed is to swap the handle and screw it into the 71-2 bracket?
Thanks Ron
Re: Is a 70 Airgrabber switch same size as a 71-2? [Re: RJS] #3061902
07/23/22 05:14 PM
07/23/22 05:14 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Handle is the only thing different among the vacuum switches.
Re: Is a 70 Airgrabber switch same size as a 71-2? [Re: convx4] #3061904
07/23/22 05:19 PM
07/23/22 05:19 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
That's what I assumed but you know what happens when you....
