Re: 727 front clutch # springs vs front clutch restrictor size [Re: moparx] #3063029
07/27/22 02:44 PM
07/27/22 02:44 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
A drilled cup plug certainly works, but a screw-in part makes more sense to me if the size is still to be worked out.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 727 front clutch # springs vs front clutch restrictor size [Re: Brad_Haak] #3063101
07/27/22 07:29 PM
07/27/22 07:29 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Why? shruggy
Master, again and still
Re: 727 front clutch # springs vs front clutch restrictor size [Re: DaveRS23] #3063251
07/28/22 11:24 AM
07/28/22 11:24 AM
Loudoun County, VA
Loudoun County, VA
Originally Posted by DaveRS23
Why? shruggy
Same reason it's a better idea to have replaceable screw-in carburetor jets than a fixed-size metering plate that you have to plug and/or re-drill every time you need to make a change. Surprised you even asked...
Re: 727 front clutch # springs vs front clutch restrictor size [Re: Brad_Haak] #3063304
07/28/22 02:06 PM
07/28/22 02:06 PM
moparx Offline
moparx  Offline
the nice thing about using a 1/8 npt female hex pipe plug, is the case hole size is perfect as is. just needs tapped for the plug.
beer
Re: 727 front clutch # springs vs front clutch restrictor size [Re: Brad_Haak] #3063417
07/28/22 07:48 PM
07/28/22 07:48 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I'm surprised you are trying to make that particular connection.
I do my share of carb tuning. And have done my share of this with the trannies. I don't see the association you are trying to make between the two, but if you somehow see some kind of advantage to tapping the case, more power to ya.
Good luck.
Re: 727 front clutch # springs vs front clutch restrictor size [Re: DaveRS23] #3063569
07/29/22 11:41 AM
07/29/22 11:41 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The advantage of a threaded socket-head plug to a cupped plug is ease of removal. If you need to experiment with different sized orifices, the advantage of a plug that can simply be unscrewed will be apparent.
Re: 727 front clutch # springs vs front clutch restrictor size [Re: John_Kunkel] #3063700
07/29/22 06:04 PM
07/29/22 06:04 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
To remove the plug I simply screw a sheet metal screw in it and pull it with a claw hammer. Not everyone has taps, but most people have a claw hammer. Either way gets the job done.
How about this; if you have the tap, then tap it. If not, use the plug?
