Re: Fuel system return line location [Re: Al_Alguire] #3062206
07/24/22 08:11 PM
07/24/22 08:11 PM
AndyF Offline
AndyF  Offline
Originally Posted by Al_Alguire
FWIW I tried a return system on my street car, ie pump gas car thats not used alot. After having to replace the return line for what would have been the third time, in 8 years I decided to NOT use the return regulator and line(mounted near carb) and just use the pump bypass. No ill affects, no issues in traffic in Vegas heat and no difference at the track, been like this for 14 years. Pump has been in the car for 22 years....Never had to touch it.
Yeah I ran an old system in my Coronet like that for the first 20 years I owned the car. A couple of Holley pumps located by the rear bumper with no regulator and a long line up to the carb. Worked fine for 20 years of street driving and street racing.
Re: Fuel system return line location [Re: AndyF] #3062279
07/25/22 02:35 AM
07/25/22 02:35 AM
I 'm a firm believer in all return lines for gasoline should enter from the bottom of the tank or cell, not spray through the air into the tanks or cells from the top or sides tsk twocents
Re: Fuel system return line location [Re: Cab_Burge] #3062294
07/25/22 07:08 AM
07/25/22 07:08 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We've been using the pump return style method for 20+ yrs, since the last 3 pumps we've had it was built in. Never an issue but I'm thinking of using one of these for added street duty reliability, but to be honest it might be overkill shruggy
https://aeromotiveinc.com/product/billet-fuel-pump-speed-controller/
Re: Fuel system return line location [Re: Tig] #3062298
07/25/22 07:47 AM
07/25/22 07:47 AM
an8sec70cuda Offline
I've had the return system on my car for 12 years now w/ no problems. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fuel system return line location [Re: an8sec70cuda] #3094135
11/14/22 01:36 PM
11/14/22 01:36 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
I'll be putting the MoPig back into service w/ the dead-head setup, but just received a new 1/2" fuel pickup w/ #8 inlet & return lines, plus a new dual-mode (dead-head or bypass) regulator from Robb Mc Performance, for when I'm ready to change to a return-line configuration. scope
Not sure how they look in the pics, but in person these parts are drool
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
