Re: Broken 727 Tail Housing Causes?
[Re: Moparrob68]
#3060747
07/19/22 11:44 PM
07/19/22 11:44 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The problem is you have too solid of a support (rear trans mount) and have enough flex in your chassis to break the tail housing. Maybe it was barelyholding up, and the engine failurepushed it over the limits. I run a mount that "floats" between rubber bisquits from bayonet end shocks. That gives it support, but i am carefull there is still a bit of give incase of severe stress. Running that deal since 1997, maybe i should check to see if i need new biscuits. 8.70s, no problems ever.
[Re: gregsdart]
#3060799
07/20/22 06:48 AM
07/20/22 06:48 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Those poly trans mounts are really stiff, I'd put something much softer in there.
68 Barracuda Formula S 340
[Re: dvw]
#3060812
07/20/22 07:59 AM
07/20/22 07:59 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I've broken two tailshaft housings w/ my cuda years ago. Both were due to twisted driveshafts. This was back when I had stock motor mounts w/ a torque strap and a poly trans mount. Car ran 10.40s then.
[Re: Moparrob68]
#3060930
07/20/22 12:43 PM
07/20/22 12:43 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Cracked the tail housing on the first pass of the year. Looking for probable causes. 1968 Cuda tube chassis car 440/727 1/4" front motor plate, 0.090 mid plate, bolt through urethane trans mount New 3.5" CM driveshaft, 1350 solid joints, 1" freeplay, same length as old 3" shaft Ladder bars with coil overs, 1degree pinion angle, so there shouldn't be much movement in the front yoke 4200 two step chip on the trans brake.
Have been running this setup 4 years, last year it broke 2 rods in a violent explosion at the 1/4 mile finish line so I suppose the shock from that could have cracks it. Just trying to avoid cracking another one as it wasn't a fun ride when the fluid got on the slicks at 135mph One degree or minus one degree. Nose up or nose down.
[Re: pittsburghracer]
#3060932
07/20/22 12:46 PM
07/20/22 12:46 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
I would look very closely at our driveshaft....Every broken tailshaft housing I have ever worked on or seen was due to a bad driveshaft.
[Re: dvw]
#3061122
07/20/22 10:04 PM
07/20/22 10:04 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
What's the front u-joint angle? Also what front slip yoke? (I've seen many sloppy billet ones which can vibrate like hell)
[Re: dvw]
#3061140
07/20/22 10:42 PM
07/20/22 10:42 PM
Posts: 108 WNY
Moparrob68
WNY
[Re: Moparrob68]
#3061145
07/20/22 11:27 PM
07/20/22 11:27 PM
Posts: 9,848 MI, usa
dvw
MI, usa
That would be my smoking gun. Unless the mid plate has some tubing across its length tied to the cage. That would leave all the fore/aft movement taken up by the trans mount. That transfers all the load to the tail shaft housing. Doug
[Re: dvw]
#3061147
07/20/22 11:46 PM
07/20/22 11:46 PM
INTMD8
Lake Villa Il
Wouldn't hurt to also check that the u-joints on the driveshaft line up. New doesn't always mean good and that's a newly introduced variable.
My experience is the same as Al_Alguire. Broken tailshaft almost always due to the driveshaft. (specifically approaching critical speed or imbalance)
[Re: INTMD8]
#3061177
07/21/22 04:59 AM
07/21/22 04:59 AM
Posts: 4,684 Wichita
GY3
Wichita
We had a u-joint retaining clip come out and a u-joint cap come out.
The driveshaft had been shortened, rebuilt and had been in the car for thousands of miles.
It happened on a backroad at the top of second gear. Sliding around in transmisison fluid at close to 100 mph.
It didn't come fully apart but just the one missing cap caused the tailshaft housing to break and the tailshaft to bend.
I use another driveshaft shop now...
[Re: SLO-KID]
#3061337
07/21/22 01:25 PM
07/21/22 01:25 PM
Al_Alguire
Las Vegas
(Artist formerly known as J-body)
You could have just changed your username ya know, rather than "starting over"
[Re: Al_Alguire]
#3061522
07/21/22 09:58 PM
07/21/22 09:58 PM
Posts: 11 AZLIVN
SLO-KID
AZLIVN
You could have just changed your username ya know, rather than "starting over" Not sure what happenedâŚ.. one day I just couldnât log in. Been lurking a couple weeks or better. âŚ..and I still have 3 727 tailshafts from âthe good ole daysâ đ
