Page 2 of 3 1 2 3
Re: update W8 dyno session! [Re: dizuster] #306069
05/03/09 10:48 AM
05/03/09 10:48 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Chris is this a CFE topend?? If it is. Is it new stuff or did you just update some older CFE stuff? Thanks Brett Miller.
Re: update W8 dyno session! [Re: W5DART66] #306070
05/03/09 11:12 AM
05/03/09 11:12 AM
Central,Ohio
FASTFISH420 Offline OP
Central,Ohio
It started life as a set of heads that Todd Patterson ran on his Pro Stock Truck..but we sent them back to CFE and had a 2008 update program done to them..
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: update W8 dyno session! [Re: FASTFISH420] #306071
05/03/09 11:23 AM
05/03/09 11:23 AM
PA
68CudaB1 Offline
68CudaB1  Offline
PA
WOW, congrats Chris X2.......close enough to 1000 for me
Now you guys have me going to send my W8's to CFE, I wonder if they have a stimulus program
Very impressive, great job!!
Re: update W8 dyno session! [Re: 68CudaB1] #306072
05/03/09 12:01 PM
05/03/09 12:01 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
nice power good job
Re: update W8 dyno session! [Re: URE] #306073
05/03/09 12:10 PM
05/03/09 12:10 PM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
I'm real pleased with the engine. Thanks for the kudos!!
There's 20 somewhere... but at this point it isn't worth a few cams, another set of headers, and wearing it out to find it... it'll be fast with what it has...
I know of a certain black car that would run 8.30's at 2950 with that mule... ran .40's with 40 less hp, and 25 less torque.
Would that "black car" be owned by an individual with the initials.....BK???
Congrats on a fine job.
Maybe I'll flush the nitrous and let ya do me a nice N/A piece.
Re: update W8 dyno session! [Re: FASTFISH420] #306074
05/03/09 12:29 PM
05/03/09 12:29 PM
The Mitten
U
URE Offline
URE  Offline
U
The Mitten
We had the heads updated at CFE, I did quite a bit of manifold work.. some things have me puzzled in the manifold but over all, good piece.
In the end, it's not a miracle, it's making the power it should make. The torque did surprise me tho... I was expecting 660... high 660's... so it's a good 15 higher which is telling... and it will not make oil temp which is also a great sign.
Re: update W8 dyno session! [Re: URE] #306075
05/03/09 12:53 PM
05/03/09 12:53 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Its a 5007420 right? Thats what you run on the 15* chevy stuff? was the intake not done by CFE at all? Thanks Brett Miller
Re: update W8 dyno session! [Re: W5DART66] #306076
05/03/09 12:57 PM
05/03/09 12:57 PM
The Mitten
U
URE Offline
URE  Offline
U
The Mitten
No I do my own intake work.
Re: update W8 dyno session! [Re: URE] #306077
05/03/09 01:04 PM
05/03/09 01:04 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
great job guys, nothing impresses me more than a stout lil' small block!
Re: update W8 dyno session! [Re: MegaDart] #306078
05/03/09 02:02 PM
05/03/09 02:02 PM
Trumbull,CT.
Trumbull,CT.
Could some of the details be given, or is it classified???
Re: update W8 dyno session! [Re: jim sciortino] #306079
05/03/09 03:05 PM
05/03/09 03:05 PM
Central,Ohio
Central,Ohio
What kinds of details do you want??
Do you think I am going to tell all his secrets..LOL
Re: update W8 dyno session! [Re: FASTFISH420] #306080
05/03/09 03:38 PM
05/03/09 03:38 PM
Trumbull,CT.
Trumbull,CT.
Anything you are willing to divulge.
Re: update W8 dyno session! [Re: jim sciortino] #306081
05/03/09 04:45 PM
05/03/09 04:45 PM
PA
68CudaB1 Offline
68CudaB1  Offline
PA
Here is my guess of the details:
R3, 9" Deck, 4.185 Bore
3.75 Stroke or close, did not calc specifics
Small Rod journals - 1.888
Lightweight crank, say 37lbs
alum 6" rods
max lightened pistons w/ all the bells - 16:1+ Compression
Obviously a nice ring pack, I will say T/S non gapless Top .043/.155, T/S Napier 2nd .043/.155 and a L/T 3MM Oil
Awesome CFE W8 heads
Large b/s cam w/ .900-1.050 lift....wont guess at duration
URE Port to 420 Intake
Nice Dominator....
How did I do ???
URE make some really nice power!! When do you think you will have it to the track?
Good luck!!!!!!!!!!!!!!!!!!!
Re: update W8 dyno session! [Re: 68CudaB1] #306082
05/03/09 04:48 PM
05/03/09 04:48 PM
The Mitten
U
URE Offline
URE  Offline
U
The Mitten
4.185 Bore
alum 6" rods
Awesome CFE heads
Lare b/s cam w/ .900-1.050 lift....wont guess at duration
Nice Dominator....
How did I do ???
Wow you nailed it!! Nice job!!
Re: update W8 dyno session! [Re: URE] #306083
05/03/09 04:51 PM
05/03/09 04:51 PM
PA
68CudaB1 Offline
68CudaB1  Offline
PA
How about my updated one.....ring pack?? Or do you have some of the funny, even smaller compression rings?? Good job URE, just because it should work, alot do not!!!!!!!!
Chris, just curious, how much power, if any, would be lost by only having a 598 intake, done by you also......just curious on your thoughts
Re: update W8 dyno session! [Re: 68CudaB1] #306084
05/03/09 05:12 PM
05/03/09 05:12 PM
The Mitten
U
URE Offline
URE  Offline
U
The Mitten
10-15 hp
Re: update W8 dyno session! [Re: 68CudaB1] #306085
05/03/09 05:45 PM
05/03/09 05:45 PM
Central,Ohio
Central,Ohio
alum 6" rods
Nice Dominator....
How did I do ???
You got the dominator part right...LOL
Chris call me..left my CSR water pump fitting at Holbrooks..
Re: update W8 dyno session! [Re: FASTFISH420] #306086
05/03/09 05:47 PM
05/03/09 05:47 PM
PA
68CudaB1 Offline
68CudaB1  Offline
PA
I know I got more than that right, URE admitted doing the 420 intake
Re: update W8 dyno session! [Re: URE] #306087
05/03/09 05:49 PM
05/03/09 05:49 PM
detroit area
moderncylinder Offline
detroit area
what gas do you run it on? that Q16 stuff?
Re: update W8 dyno session! [Re: moderncylinder] #306088
05/03/09 10:25 PM
05/03/09 10:25 PM
Central,Ohio
Central,Ohio
Yeah..we use the Q-16 stuff.makes alittle more power than the C-25 and alot cheaper..
Page 2 of 3 1 2 3
