KYB shocks, any good? #3059771
07/16/22 11:20 PM
07/16/22 11:20 PM
BlueRacer69 Offline OP
Thinking of replacing my old shocks with a new set of KYB shocks. Are they any good? Let me have your opinion. It's a Dart 383. Thanks.
Re: KYB shocks, any good? [Re: BlueRacer69] #3059774
07/17/22 12:22 AM
07/17/22 12:22 AM
AndyF Offline
AndyF  Offline
They are the wrong choice if you have big torsion bars. They might work okay if you have a really soft suspension.
Re: KYB shocks, any good? [Re: AndyF] #3059780
07/17/22 12:45 AM
07/17/22 12:45 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Really stiff. I didn’t care for them on a car that had hard bushings, big bars, etc. was so bad I never bought another set as I just couldn’t see anything riding good with them.
I want my fair share
Re: KYB shocks, any good? [Re: SomeCarGuy] #3059781
07/17/22 12:52 AM
07/17/22 12:52 AM
Kirkland, Washington
Pacnorthcuda Offline
I have them on a 70 big block Cuda, and have run them on 318 Volare too.. for awhile they were the go to shock….but they are stiff. Depends on your roads, your driving style, your butt. I wouldn’t buy them again, but I’m also not taking them off my Cuda.
Re: KYB shocks, any good? [Re: Pacnorthcuda] #3059864
07/17/22 09:18 AM
07/17/22 09:18 AM
Thanks for that info guys. So what brand shocks would you recommend? Sound off.
Re: KYB shocks, any good? [Re: BlueRacer69] #3059866
07/17/22 09:56 AM
07/17/22 09:56 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I had them on my car and could not wait to get them off. Way too stiff for my liking. I ended up using Monroes.
Re: KYB shocks, any good? [Re: mopars4ever] #3059873
07/17/22 10:26 AM
07/17/22 10:26 AM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
I have them on my 69 B'cuda BB. I see no problem with them.
Re: KYB shocks, any good? [Re: Dcuda69] #3059898
07/17/22 12:14 PM
07/17/22 12:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have used KYB's almost exclusively on my own as well as customer's cars for over 40 year (20+ customer wise). During that time I had one customer that said they were too stiff so we swapped them for Gabriel's. Monroe's IMO are total cr-p and may as wel l stay with a 100,000 mile shock or strut. twocents beer
Re: KYB shocks, any good? [Re: TJP] #3059933
07/17/22 02:10 PM
07/17/22 02:10 PM
SomeCarGuy Offline
SomeCarGuy  Offline
I run bilsteins these days whenever I need a set. For everyday use, somewhat spirited driving of classics. On diesel pickups. Whatever I need them for. Before that I ran edelbrock so and have yet to find a better setup than those had. Somebody on here said they were a copy of a 50s or so mopar shock valve that instantly changed from stiff to soft basically. Not made anymore. Bummer.
Re: KYB shocks, any good? [Re: SomeCarGuy] #3059946
07/17/22 02:52 PM
07/17/22 02:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Oriflow shocks is what they were called. My 51 had them originally. If they worked new anything like they did when I replaced them earlier this year, they suck. I found a set of Doetsch shocks that can be made to fit, much much much better than the originals. I will give the originals the benefit of the doubt right now, as they were 70 years old when I replaced them. I think the Edelbrock shocks used the same concept with a lot of updating since then, like being gas charged,
Re: KYB shocks, any good? [Re: BlueRacer69] #3059969
07/17/22 03:58 PM
07/17/22 03:58 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Check out Bilsteins or Konis...
Just my $0.02... wink
Re: KYB shocks, any good? [Re: Sinitro] #3059981
07/17/22 04:42 PM
07/17/22 04:42 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
They are the worst shock I have ever used
Re: KYB shocks, any good? [Re: CSK] #3059984
07/17/22 04:50 PM
07/17/22 04:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
They have rightfully earned their nickname....
Kill
Your
Butt.
They are a crutch for a softly sprung car. The way that they function is that for the first part of travel, they are stiff....then they soften up as the suspension compresses..
This is exactly backwards of a decent shock that is initially soft but firms up through the range of travel.
As Andy wrote, in a car with soft springs, they will firm up the ride but in a stiffer sprung car, they are terrible.
I had KYBs in my car with 1.0 torsion bars and 440/Hemi leaf springs. It rode rough but I lived with it. Later, I swapped in 1.15" torsion bars but switched to Bilstein RCD shocks and the car actually rode better.Bigger torsion bars and better shocks but it actually rode much better.
Re: KYB shocks, any good? [Re: Kern Dog] #3060019
07/17/22 08:08 PM
07/17/22 08:08 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have them on the front my Savoy but it still has the slant six bars on it. It doesn't ride terrible but I am going to a new set of Koni shocks up front.
Gus beer
64 Plymouth Savoy
Dana 60
Re: KYB shocks, any good? [Re: fourgearsavoy] #3060041
07/17/22 09:36 PM
07/17/22 09:36 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I have KYBs on the front and rear of my '67 Barracuda Fastback. 440/727/S-60 combo. I have thick T-bars (1+ inch versions) + SS springs in the rear.
The shocks do not stand out to me as being soft,or harsh.
Maybe the ride sensor in my butt has gone out of calibration?
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: KYB shocks, any good? [Re: 19swinger70] #3060056
07/17/22 11:26 PM
07/17/22 11:26 PM
Minnesota
RROD Offline
RROD  Offline
Minnesota
Installed a rear set on a 71 cuda. You could push down on the rear bumper and the rear end would not move. No give at all. Very stiff ride. Removed them and installed some Monroe shocks. Ride is much better.
Re: KYB shocks, any good? [Re: RROD] #3060062
07/18/22 12:25 AM
07/18/22 12:25 AM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
I installed QA1 single adjustable for my street driven 71 Barracuda.
Really like them. Just dial up or down the firmness.
Re: KYB shocks, any good? [Re: skdmark] #3060064
07/18/22 12:39 AM
07/18/22 12:39 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I wasn't expecting to see people citing the KYB is being too stiff. I put a set on my dad's 63 corvair last fall because the shocks on it were so worn out. After installing the new KYB gas adjust shocks, there is no difference between the KYBs and the old worn out shocks. If I bounced on the bumper, it would continue oscillating up and down about five times, almost as if there was no shock absorber on it at all. So in my experience they were not too stiff, they were way too soft.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: KYB shocks, any good? [Re: Hemi_Joel] #3060138
07/18/22 11:02 AM
07/18/22 11:02 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Got a set on the front of my '66 Charger and that old tank drives pretty good. SS springs on the back with the matching MP shocks and I can't complain about the launch with Drag Radials or just driving around. Weighed 4150 with me in it last time I took it across the scales. I would buy another set for a heavy car like this one. wave drive
