Re: KYB shocks, any good?
[Re: AndyF]
#3059780
07/17/22 12:45 AM
07/17/22 12:45 AM
Posts: 10,234 Someplace you aren't
SomeCarGuy
Really stiff. I didn’t care for them on a car that had hard bushings, big bars, etc. was so bad I never bought another set as I just couldn’t see anything riding good with them.
I want my fair share
[Re: mopars4ever]
#3059873
07/17/22 10:26 AM
07/17/22 10:26 AM
Posts: 4,963 WI
Dcuda69
WI
I had them on my car and could not wait to get them off. Way too stiff for my liking. I ended up using Monroes. I have them on my 69 B'cuda BB. I see no problem with them.
[Re: TJP]
#3059933
07/17/22 02:10 PM
07/17/22 02:10 PM
SomeCarGuy
I run bilsteins these days whenever I need a set. For everyday use, somewhat spirited driving of classics. On diesel pickups. Whatever I need them for. Before that I ran edelbrock so and have yet to find a better setup than those had. Somebody on here said they were a copy of a 50s or so mopar shock valve that instantly changed from stiff to soft basically. Not made anymore. Bummer.
[Re: SomeCarGuy]
#3059946
07/17/22 02:52 PM
07/17/22 02:52 PM
Posts: 6,331 nowhere
Sniper
nowhere
I run bilsteins these days whenever I need a set. For everyday use, somewhat spirited driving of classics. On diesel pickups. Whatever I need them for. Before that I ran edelbrock so and have yet to find a better setup than those had. Somebody on here said they were a copy of a 50s or so mopar shock valve that instantly changed from stiff to soft basically. Not made anymore. Bummer. Oriflow shocks is what they were called. My 51 had them originally. If they worked new anything like they did when I replaced them earlier this year, they suck. I found a set of Doetsch shocks that can be made to fit, much much much better than the originals. I will give the originals the benefit of the doubt right now, as they were 70 years old when I replaced them. I think the Edelbrock shocks used the same concept with a lot of updating since then, like being gas charged,
[Re: Sinitro]
#3059981
07/17/22 04:42 PM
07/17/22 04:42 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
They are the worst shock I have ever used
[Re: Kern Dog]
#3060019
07/17/22 08:08 PM
07/17/22 08:08 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have them on the front my Savoy but it still has the slant six bars on it. It doesn't ride terrible but I am going to a new set of Koni shocks up front. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3060041
07/17/22 09:36 PM
07/17/22 09:36 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I have KYBs on the front and rear of my '67 Barracuda Fastback. 440/727/S-60 combo. I have thick T-bars (1+ inch versions) + SS springs in the rear. The shocks do not stand out to me as being soft,or harsh. Maybe the ride sensor in my butt has gone out of calibration?
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: RROD]
#3060062
07/18/22 12:25 AM
07/18/22 12:25 AM
Posts: 117 SE-WI
skdmark
SE-WI
I installed QA1 single adjustable for my street driven 71 Barracuda. Really like them. Just dial up or down the firmness.
[Re: skdmark]
#3060064
07/18/22 12:39 AM
07/18/22 12:39 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I wasn't expecting to see people citing the KYB is being too stiff. I put a set on my dad's 63 corvair last fall because the shocks on it were so worn out. After installing the new KYB gas adjust shocks, there is no difference between the KYBs and the old worn out shocks. If I bounced on the bumper, it would continue oscillating up and down about five times, almost as if there was no shock absorber on it at all. So in my experience they were not too stiff, they were way too soft.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
