It could save you II (Autotopia 64 Merc Comet Crash) #3057597
07/09/22 08:19 AM
07/09/22 08:19 AM
Wichita Kansas
B Dartman Offline OP
Wichita Kansas
DVW posted a thread about inspecting your race car - it could save you.. Check this video out. Good analogy in hindsight....
Autotopia Crash
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: B Dartman] #3057605
07/09/22 09:17 AM
07/09/22 09:17 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
The throttle's sticking
I'm having to ride the brakes
They were sort of given two warnings but chose to ignore them.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: B Dartman] #3057614
07/09/22 09:55 AM
07/09/22 09:55 AM
Mo.
racerx Offline
racerx  Offline
Mo.
This is scary. eek I've been in similar situation.
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: B Dartman] #3057638
07/09/22 11:53 AM
07/09/22 11:53 AM
He should have turn the ignition off right away, too bad he didn't shruggy
I had a similar experience years ago when I forgot to reattach a spark plug wire holder on my old max wedge car(1963 Plymouth Belvedere sedan) driver side carb and it ended up getting stuck under the throttle linkage making the motor stay at around 3500 RPM in low gear after showing off driving into the yard at work, I went through chain link fence and scratched up some of the trim around the windshield and broke off the "426" emblem off the hood whiney
I got lucky that it didn't do any other damage to the car or me or at work boogie
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: Cab_Burge] #3057753
07/09/22 07:20 PM
07/09/22 07:20 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Jamming it in reverse would have made for a violent and messy slow down but likely would have helped substantially. Easy to say from the ouch.
Looking at the video again i don't know that I could get one of those junk shifters in reverse during a stressful moment, I hate those things!
68 Barracuda Formula S 340
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: Bob Stinson] #3057793
07/09/22 09:34 PM
07/09/22 09:34 PM
PA
moparacer Offline
moparacer  Offline
PA
The brakes would have been fine if the throttle sticking issue would have been fixed.
Those look like the Dynalite's I have on my drag car from way back in the day. Nice and light but don't try to stop in a hurry.They were never intended for street use with those rotors IIRC.
Watching him face plant the metal dash brought back bad memories for me when I was a kid, was riding in a 70s Dodge van and the driver wasn't paying attention, rearended someone and my friend face planted the steel dash....Knocked out all his front teeth on the top and bottom. Wasn't pretty.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: B Dartman] #3057797
07/09/22 10:03 PM
07/09/22 10:03 PM
CA
crackedback Offline
crackedback  Offline
CA
Hi Performance car
Low performance driver
Bad outcome.
Just click the thing OFF. Instead of grabbing the shifter, hit the kill/key/whatever to shut it down.
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: crackedback] #3057838
07/10/22 12:10 AM
07/10/22 12:10 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
This kind of thing is not that uncommon. He had a TV show there to film his new car, he didn't want to stop and ask them for time to fix the car. I've seen guys get out on the racetrack with obvious and dangerous problems because they didn't want to miss that round. Or guys get in a car to drive to work because they don't want to be late or miss a day and they know the car is unsafe and don't have time to fix it right now.
Several years back there was a farmer around here hauling a load of silage in an old 2-ton flatbed. He plowed through a red light and wiped out a family. There were a half a dozen empty cans of brake fluid in the cab. He had been trying to pour it into the master cylinder under the floor every time he needed brakes because it was leaking out so fast.
It's all the same line of thinking. I'll be okay this one time, I'll fix it after. Similar to people getting hurt at work. Most of the time they say"I knew I shouldn't have done that".
There are so many things in life that we do that can't be undone. We need to do a good job of thinking ahead of what the consequences could be of careless behavior.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: Cab_Burge] #3057962
07/10/22 12:26 PM
07/10/22 12:26 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I had something similar happen where the damn wire harness for the lean burn somehow made its way to jamb the throttle open. I turned the ignition off immediately after realizing the brakes were not going to stop the car. It was an interesting few seconds navigating a twisting winding mountain road to say the least.
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: mgoblue9798] #3058048
07/10/22 08:19 PM
07/10/22 08:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A comedy of errors with an inevitable conclusion. Dont know anything about the guy or shop he represents narrating the video but the fact he knew about a sticking throttle and still agreed to the shoot/drive says volumes to me.
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: Al_Alguire] #3058050
07/10/22 08:26 PM
07/10/22 08:26 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
His "Won't go to the track because he might wreck it" did not age well.
Good thing they had those nice belts on.
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: slantzilla] #3058220
07/11/22 12:58 PM
07/11/22 12:58 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Car gave them plenty of warning signs that they just ignore. Can't fix stupid.
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: B Dartman] #3058224
07/11/22 01:15 PM
07/11/22 01:15 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I didn't bother watching the whole sh!t-show... saw & heard enough before seeing it all play out in agonizing detail runaway
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: Brad_Haak] #3058625
07/12/22 03:48 PM
07/12/22 03:48 PM
moparx Offline
moparx  Offline
as i always like to say, "it ain't the speed that does you in, it's the sudden stop that does it every time !" biggrin
beer
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: moparx] #3058628
07/12/22 03:57 PM
07/12/22 03:57 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: Bad340fish] #3058638
07/12/22 04:15 PM
07/12/22 04:15 PM
moparx Offline
moparx  Offline
up bow that's it !
beer
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: moparx] #3058855
07/13/22 12:01 PM
07/13/22 12:01 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I saw a guy in a better get loose around 80’ out and he got out, then nailed the gas again. I thought it looked like a bad deal right then for some reason, just struck me funny how it looked. The throttle hung open and it being a pro level like blower car, it ran out the back end of the eight full blast and was doing at least 175 when it plowed the oak tress well beyond the shut off.
Every one of us in my group that day thought shutting it down was the most obvious thing to do, but not being in the heat of the moment I don’t know if it would’ve occurred to do that. I think you have to have that in your mind as a reflex when you strap in or you will end up with a helicopter ride or worse.
The ihra pro stock driver I knew personally was with us that day. He said he never got back in when a run went to crap like that. His family ran the car themselves and as more of a hobby, it wasn’t worth it to push things to the absolute edge.
I want my fair share
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: SomeCarGuy] #3058876
07/13/22 12:57 PM
07/13/22 12:57 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Cliff notes? Pushrod fell out? Brakes just didn't work right? Billy Bob designed the system? Couldn't get it bled? Looked like a lawn sprinkler when he pushed the pedal?
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: CMcAllister] #3058887
07/13/22 01:26 PM
07/13/22 01:26 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Oh my. I have had a few run away muscle cars over the years and two things need to happen - 1) click it off! and 2) put it in f'ing neutral man! Not a whole lot of self preservation going on with either of those gentlemen.
Always wear your safety belt!!! The passenger was probably picking red PPG chips out of his teeth after that.
I find it funny that they say it was a brake problem when the car was clearly under power. Is the driver an experienced racer?
Re: It could save you II (Autotopia 64 Merc Comet Crash) [Re: CMcAllister] #3058916
07/13/22 02:36 PM
07/13/22 02:36 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I wondered about that too, but I haven't seen a definitive explanation. He did a follow-up video where he took questions from the audience, and he talked about it maybe being the brakes being over heated (from riding them) and boiling the brake fluid.
When I watched the crash video, it seems like the driver has his foot go to the floor when he's hitting the brakes.. not just unresponsive brakes that took more effort that usual. I think that's why the boiling brake fluid explanation makes sense to me.
