Re: U joint question - swapped center section [Re: MoparJoe] #305777
05/04/09 07:38 AM
05/04/09 07:38 AM
scratchnfotraction Offline
I am running a 7260/1330 conversion joint
large size has 1" caps and is 3 5/8 across,has tabs on the yoke to hold the caps in with straps...no clips
small side has clips to hold the caps in with straps
I found it under a 67 polar with a 3.23/742 case with HP440 or 426 also will cross over to a ford/crysler conversion joint
I dont have my napa part # handy but will get it and post it later
measure across the yoke,put the straps on and measure the cap
small,large,larger are the u-joints
Re: U joint question - swapped center section [Re: scratchnfotraction] #305778
05/04/09 09:37 AM
05/04/09 09:37 AM
City of Champions
P
Prostock Offline OP
Prostock  Offline OP
P
City of Champions
I'll measure again tonight. Thanks!
Re: U joint question - swapped center section [Re: Prostock] #305779
05/05/09 09:44 AM
05/05/09 09:44 AM
City of Champions
P
Prostock Offline OP
Prostock  Offline OP
P
City of Champions
I called a local driveline shop and explained my situation. They said they should be able to fix it up. I'm going to drop the driveshaft and the straps off tomorrow.
Thanks again for the help!
Re: U joint question - swapped center section [Re: DAYCLONA] #305780
05/05/09 09:46 AM
05/05/09 09:46 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
No part number off hand, but there is a conversion joint available from CarQuest, and Autozone,....it's a cheapy,...I'd recommend you stop by a driveshaft shop and get the Splicer brand, unless CQ or AZ can get can assure you of the Splicer brand,....I have two cars running the conversion joints,...no problems,......also contact DrDiff here on Moparts, I believe he has conversion joints as well
I might have to do that if I can't find a slip yoke for the trans. Should be ok. I ran 12.0's with one on the rear w/ zero problems
Coming soon!!!!
