Valve to valve guide tolerance #3057304
07/07/22 10:45 PM
07/07/22 10:45 PM
State, country, etc.
gss Offline OP
gss  Offline OP
I have a pair of fresh zero mile 340 heads that will go on a mild cammed engine for street use. They have new Ferrea valves and bronze liners. There is a little lateral movement in the valves when I wiggle them. I usually don't feel any slop in fresh heads. How much is too much?
Re: Valve to valve guide tolerance [Re: gss] #3057312
07/07/22 11:31 PM
07/07/22 11:31 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
loose better than tight
too tight will stick a valve open
measure distance between valve heads
Re: Valve to valve guide tolerance [Re: gss] #3057326
07/08/22 12:57 AM
07/08/22 12:57 AM
3/8 intake valves from .00175 to .00225 with bronze guides and good Teflon seals, .0020 to .00250 on the stock size 3/8 valves on exhaust sides has works very well for me the last 30 +years on stock cast iron Mopar heads with bronze liners, BB, Hemi and SB up twocents
Re: Valve to valve guide tolerance [Re: Cab_Burge] #3057846
07/10/22 01:12 AM
07/10/22 01:12 AM
gss Offline OP
gss  Offline OP
They measure .002 pretty much across the board up
