Re: POWER DRAGON D150 build
[Re: modelmakerinc]
#3143142
05/08/23 08:07 AM
05/08/23 08:07 AM
Posts: 2,345 west palm beach, florida
modelmakerinc
After a Day of welding and giving myself a bit of "Sunburn" I lightly used flap wheels on the welds just to even it out a bit and several styles of wire brushes to remove all the loose material from the rails in prep for POR-15 I really like the stuff but messy! and the S**T dont come off your skin if you let it dry. I brushed the first coat on to get around and behind all the corners and cubbys. the second coat i sprayed with my primer gun. Ill say again i do like POR-15. for this type of build.
[Re: modelmakerinc]
#3144648
05/15/23 07:22 AM
05/15/23 07:22 AM
modelmakerinc
plumbed new axle brake lines,finished install of fuel cell and feed line, the vent line need the bed to find placement, I rebuilt w/ all new parts rear brakes , got the Park brake cables in, drive shaft and all the suspension hardware tight (I still will need to add jam nuts or lock nuts after final adjustment when the truck is back together)
[Re: modelmakerinc]
#3184314
10/16/23 09:03 AM
10/16/23 09:03 AM
modelmakerinc
its been 4 months of work and other time eating life to-dos. So I'm back at it for a good final push. The build left off with too small a tire and wheel width and the 318 was ready to come out. this is the new tire wheel difference, just under 3" of additional width
[Re: modelmakerinc]
#3189259
11/07/23 07:39 AM
11/07/23 07:39 AM
modelmakerinc
everything is buttoned up below and behind the camshaft, the front of the engine and accessories are next, a bit of wiring and some gauges, complete the brake system then its run in and play.
there is only .100 distance from the valve cover to the brake booster for those curious. hope to never remove the valve cover:) 1984 D250 booster and master, had to shorten the push-rod by 5/16" and ream the master cyls bolt holes out to 3/8"
[Re: modelmakerinc]
#3189568
11/08/23 08:45 AM
11/08/23 08:45 AM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
there is only .100 distance from the valve cover to the brake booster for those curious. hope to never remove the valve cover:) 1984 D250 booster and master, had to shorten the push-rod by 5/16" and ream the master cyls bolt holes out to 3/8" had the same valve covers/Power booster issue.. wound up grinding the fins off the covers adjacent to the booster
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3190569
11/13/23 08:50 AM
11/13/23 08:50 AM
modelmakerinc
Getting the underside wrapped up, my nephew had supplied me with a pair of dirt track mufflers on a 3" headpipe with a handful of bends that was installed under some car and I had a few little pieces from some other build. It was decently made with really nice smooth bends so it was up to me to break humpty dumpty apart and piece it back together again,
I cut a muffler off with part of a bend and it became the outlet, cut the other muffler out and matched the down pipe, now I am starting with a matched pair to build the rest of the system. I built the driver side choosing within my inventory of bends, then used the remaining bits for the pass side. they are a bit different from side to side since I had to use what was remaining and the crossmember on the pass side needed a soft double curve for clearance.
