Re: Exhaust with mini tubs, etc
[Re: Stanton]
#3056511
07/06/22 02:30 AM
07/06/22 02:30 AM
Posts: 43,244 Bend,OR USA
Cab_Burge
[Re: Stanton]
#3056566
07/06/22 09:30 AM
07/06/22 09:30 AM
Posts: 31,051 Oregon
AndyF
'69 RR - minitubbed and springs moved inboard. Want to run the exhaust all the way to the rear and would like to see what others have do in this situation. It can be done but it requires a good fab guy. Not some monkey over at House of Exhaust. I've done a couple of cars like this and it requires a full day of cutting, bending, welding, fabricating mounts, etc.
[Re: Stanton]
#3057015
07/07/22 07:42 AM
07/07/22 07:42 AM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
I think this will be the way to go ... Maybe I'm looking at it wrong but the OP said the springs were moved inboard, which I took to mean they're mounted in the frame rail. If so that looks nice and all but it won't work unless they lose the leaf springs.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: Stanton]
#3057017
07/07/22 07:46 AM
07/07/22 07:46 AM
Posts: 6,291 nowhere
Sniper
nowhere
I think this will be the way to go ... exhaust systems tend to change length as they heat up, which is why OEM's allow for it in their mounting. Bolting it solidly tot eh frame rail is probably not a good idea, unless it;s a trailer queen.
[Re: Bob Stinson]
#3057077
07/07/22 11:25 AM
07/07/22 11:25 AM
Posts: 8,889 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I think this will be the way to go ... Maybe I'm looking at it wrong but the OP said the springs were moved inboard, which I took to mean they're mounted in the frame rail. If so that looks nice and all but it won't work unless they lose the leaf springs. Well, I'm both the OP and the one who posted those photos and I noticed the problem right after I posted them
[Re: Sniper]
#3057078
07/07/22 11:28 AM
07/07/22 11:28 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I think this will be the way to go ... exhaust systems tend to change length as they heat up, which is why OEM's allow for it in their mounting. Bolting it solidly tot eh frame rail is probably not a good idea, unless it;s a trailer queen. Modern day flex pipe similar to this - problem solved !!
[Re: Stanton]
#3057192
07/07/22 03:22 PM
07/07/22 03:22 PM
Sniper
nowhere
[Re: topside]
#3057195
07/07/22 03:32 PM
07/07/22 03:32 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
What about a narrower gas tank ? Then the tailpipes could run just inside the rails, from 90-degree insulated hangers. Good idea ... where do I get that !!
[Re: rapom]
#3057392
07/08/22 12:29 PM
07/08/22 12:29 PM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
Mine is an A body Mini tube. I made my own 3 inch custom exhaust and modified my gastank(stainless). Just some ideas for you.
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: davesmopars]
#3057426
07/08/22 02:32 PM
07/08/22 02:32 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
^ That's the pipe routing I was considering for mine, since I don't care about stock tips, stock tip hangers, precise stock tip locations, etc
If the stock leaf spring mounting structure is still there after the relocation, it'll make a handy place to mount exhaust hangers.
I haven't had tailpipes since the 90s....
Rich H.
Esse Quam Videri
