Let’s talk ac systems #3056451
07/05/22 08:15 PM
07/05/22 08:15 PM
houston texas
gremlinsteve Offline OP
houston texas
My newly purchased truck. A 80 model d100
Has no ac. It’s 103 today and as I’m sweating my ass off I’m curious who has used an underdash
Unit in the truck. If and what type. Has it performed well?
Because I love my truck but I’m begging for ac now
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Let’s talk ac systems [Re: gremlinsteve] #3056456
07/05/22 08:34 PM
07/05/22 08:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
An under dash add on system should have no problem cooling that truck.
Re: Let’s talk ac systems [Re: gremlinsteve] #3056461
07/05/22 08:38 PM
07/05/22 08:38 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Only experience was an '83 Ram with dealer add on A/C. FAR superior cooling to the factory units of the era.
Old school linky 15,000 BTU and 290 CFM should be fine with your truck.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Let’s talk ac systems [Re: 3hundred] #3056504
07/06/22 01:19 AM
07/06/22 01:19 AM
San Diego
JP8 Offline
JP8  Offline
San Diego
https://www.oldairproducts.com/
Old Air Products
1201 Forum Way South
Fort Worth, TX 76140
Hurricane
IP-400HCDE - Inside Package, A/C Heat and Defrost Unit
Underdash A/C Heat and Defrost Unit, Slimline (coil right, Electronic Heater Valve)
$550.00
Instagram : @5_points_racing
Re: Let’s talk ac systems [Re: JP8] #3056619
07/06/22 12:04 PM
07/06/22 12:04 PM
moparx Offline
moparx  Offline
i can't add truck experience, but did two universal application, e-bag cheapies, that worked very well.
one on a 64 ford galaxie 500, and another on a 58 chebby impala.
these kits contained cut to length hoses, a bunch of assorted fittings in different angles, polished new style compressor, dryer, etc, as well as the under dash evaporator and control unit.
these have been in service for 5 or 6 years with absolutely no problems, and cool these cars great, putting out 40 degree air temperature.
i can't tell you how many btu's these kits put out, however.
you also have to make mounting brackets for the compressor to fit your engine. that was a simple procedure here.
if you have some fab skills, it shouldn't be too hard of an addition to add to your truck.
just my experience. your mileage will vary.
beer
Re: Let’s talk ac systems [Re: moparx] #3058368
07/11/22 07:21 PM
07/11/22 07:21 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
I converted my '71 (Sweptline) 318 and the wife's '79 LRE to the modern Sanden compressor since the intake I used on both wouldn't work with the factory RV2 monster. I found a newer model of the same engine (for each one) with the Sanden and striped the entire front of brackets, pulleys, bolts, etc. Easy bolt-up with a brand new compressor and had new lines made. If you can buy the under-dash unit by itself, junkyard bracket set, and pick up a compressor/condensor/dryer/most hoses from Rock Auto, you can do the job without laying out a ton of cash.
