Re: Late model Challenger Q’s
[Re: Dart 500]
#3057202
07/07/22 04:17 PM
07/07/22 04:17 PM
Posts: 1,185 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I havent been on the scene with those cars since I sold mine but didnt they fix the wheel hop issues in 2015? I know the older stick cars were brutal for it.
Nope. My 1320 w/ the OEM Nexen 275/40R20 drag radials either dead-hooks or spins & hops. I can only imagine how bad a stick car can be. That's one of the reasons for suggesting extra wheels to use tires with taller sidewalls that absorb a lot of the hit. My car may not have hooked 100% of the time since I started using 305/40R18 ET Street S/S, but it hasn't hopped w/ 'em. ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: redraptor]
#3061578
07/22/22 10:26 AM
07/22/22 10:26 AM
Brad_Haak
Loudoun County, VA
Re diff brace: if the car is still under warranty, has a braced added, and there is a differential problem, the dealer will not honor the warranty for that issue. Despite any argument that a brace should reduce issues, this is what I've been told.
[Re: Brad_Haak]
#3061634
07/22/22 02:31 PM
07/22/22 02:31 PM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
Re diff brace: if the car is still under warranty, has a braced added, and there is a differential problem, the dealer will not honor the warranty for that issue. Despite any argument that a brace should reduce issues, this is what I've been told. I have no doubt that is true, unless Stellantis issues a statement stating otherwise very specifically. The rears seem to have proven themselves to be the weak link in the drivetrain when pushed hard on sticky tracks.
[Re: redraptor]
#3093261
11/10/22 09:32 PM
11/10/22 09:32 PM
Posts: 553 Stuart FL
mercman1
Stuart FL
The autos are quicker everywhere...drag strip or road course. I have a 2010 SRT 6spd that has gone 13:10 at 109 sliding the clutch and slipping the tires. Wheel hop is a problem. The 6.4 auto cars will run 12.20 off the show room floor all day. I have dedicated drag cars, so I now road course mine. Mostly at Sebring and Daytona. Motor is bone stock and at Daytona it will see 167 MPH at the Start /Finish line lap after lap. Here is a video of me toying with a BMW M2 that was lighter and "claimed" more horse power. Towards the end you see me leave a ZL1 Camaro in the corners. The ZL1 with almost 250 more horsepower smoked me on the long straight. Amazing how many people come up to me and say " I had no clue Challengers could turn". check out... https://youtu.be/fmINjZazD4M
