Re: Stabil in non-alcohol gasoline ?
[Re: hemienvy]
#3055697
07/04/22 12:32 AM
07/04/22 12:32 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
If it will be more than a few months then I’d still add it. You could run the regular version instead of the stabil 360. I’ll venture a guess pure gas will last a very long time, but for the few bucks I wouldn’t risk having to deal with it. Also if you decide later to add it because you aren’t driving as much as you plan or have a breakdown that keep it off the road a spell, the gas will have already gone downhill somewhat.
I want my fair share
[Re: SomeCarGuy]
#3055720
07/04/22 08:50 AM
07/04/22 08:50 AM
Posts: 10,752 North Dakota
6PakBee
North Dakota
Seafoam. I wouldn't use Stabil in my lawnmower, any flavor.
[Re: 6PakBee]
#3055739
07/04/22 10:54 AM
07/04/22 10:54 AM
Posts: 3,113 N.W. Florida
Fat_Mike
N.W. Florida
Seafoam. I wouldn't use Stabil in my lawnmower, any flavor. X2
[Re: mgoblue9798]
#3055840
07/04/22 01:07 PM
07/04/22 01:07 PM
Posts: 21,538 N.E. OHIO, USA
A12
N.E. OHIO, USA
Pure gas without ethanol will not absorb or combine with water at all.
Fill a glass jar with gas then add some water.
After it all settles the water will be on the bottom of the jar obviously separated from the fuel.
If you store gas air tight in a full container or tank, and empty the carb of fuel, it will store just fine for a long time. What about water contamination from condensation and humidity?
[Re: Fat_Mike]
#3055855
07/04/22 01:52 PM
07/04/22 01:52 PM
Posts: 19,589 north of coder
moparx
Seafoam. I wouldn't use Stabil in my lawnmower, any flavor. X2 i agree as well. i had to deal with a tar or gummy issue only once using stabil, to convince me !
[Re: moparx]
#3056032
07/05/22 12:08 AM
07/05/22 12:08 AM
SomeCarGuy
I’ve been using stabil for decades. Never had a carb gum up, not once. Small power. Cars. Not ever. Now people that I’ve told how to stop their carb issues and response to use it on the other hand…many. Put the proper amount in, use it no longer than two years and you’ll be fine. Use old product or fail to add fresh treated gas within two years, sure I’ll bet you have issues.
The stabil 360 is the ticket these days since it can cope with ethanol
[Re: Charger727]
#3056294
07/05/22 02:04 PM
07/05/22 02:04 PM
moparx
Used Stabil in my mopars for over 25 years - no problems BUT...
Always made sure I mixed with a full tank before storage - noting the mixing guidelines on the bottle instructions Always made sure I burned up almost all of that tank in the spring before adding new gas
My brother on the other hand....
Kept mixing Stabil in his 4-wheeler every fall - until it wouldn't start The shop drained the gas and it was a red gooey mess - he never burned through the entire tank and kept adding Stabil for years until it there was way too much in the "mix" that may have been the cause of the gooey mess i had to clean up, although it was more of a brownish shade than red. the car had not been driven in many years, and all i knew about the storage during that time, was stabil was in the tank.
